Old 04-12-2011, 12:37 PM   #1
Tonavi
Tonavi's Avatar
Drives: 2007 Yaris HB
What gauges you leave your SGII on?
I use:
UL - instant MPG
LL - *FIA, air intake temp
UR - AVG MPG, resets every startup
LR - *FWT, water temp
Tonavi is offline   Reply With Quote
Old 04-12-2011, 12:52 PM   #2
swidd
Drives: Yaris HB
If there develops a trend through this thread for certain information displayed, it could probably be a good starting point for the CTScott YarGauge default display mode.
swidd is offline   Reply With Quote
Old 04-13-2011, 12:46 AM   #3
Idahotom
Drives: 2008 5 sp. LB
water temp
MPG
RPM
MPH (Yeah I know that gives me two speedos, but I'm always already looking at the ScanGauge anyway)
Idahotom is offline   Reply With Quote
Old 04-13-2011, 09:50 AM   #4
rick996
rick996's Avatar
Drives: 2010 5 door hatch w/5 sp man.
Right now:
Instant MPG
Avg MPG
Cost so far today
MPH (I never got used to reading the center speedo at an angle )
I will be changing Cost so far today to Engine load.
I also realized that mine has XGauge so I will be looking for other useful gauges.
rick996 is offline   Reply With Quote
Old 04-13-2011, 10:26 AM   #5
Tonavi
Tonavi's Avatar
I don't see how many hate the center gauges. They never bothered me, not even when the car was new! I kinda think gauges behind the steering wheel are weird lol.
Old 04-13-2011, 10:39 AM   #6
DMZ
DMZ's Avatar
Drives: 2007 Yaris LB
I agree. And I bet most people have their SGII mounted on the center console. I do in my Tundra, easier to see.
DMZ is offline   Reply With Quote
Old 04-13-2011, 11:11 AM   #7
rick996
rick996's Avatar
Excuse the dust:
Old 04-13-2011, 11:41 AM   #8
Tonavi
Tonavi's Avatar
I kept mine there, too, but my velcro peeled off in the summer heat. The ethernet cable in the back is wadded up and I jammed in between the glove box and steering wheel. It stays there on its own quite nicely!
Old 04-13-2011, 12:30 PM   #9
rick996
rick996's Avatar
So did mine and left a sticky mess. This year I'm trying 3M Dual Lock like they use on the toll transponders. I'll let you know how it works.
Old 04-13-2011, 12:39 PM   #10
Tonavi
Tonavi's Avatar
Mine left no mess, just fell off one day. I thought about coming up with a solid mounting solution but decided against it since it stays on the column fine as it is. I've seen some creative mounting points for them though.
Does anyone have the new SG that supposedly displays power output? I have a first gen one, got it in May 2009.
Old 04-13-2011, 01:21 PM   #11
rick996
rick996's Avatar
I swear I got mine before then. Mine was relabeled as a "Fuel Efficiency Advisor". It doesn't say ScanGauge anywhere on it. But it is a ScanGaugeII with XGauge.
You can check bu entering MORE>MORE>MORE> and see if XGAUGE is a choice.
Here is a link on how to set it up for horsepower:
http://www.scangauge.com/support/horsepower.shtml
Old 04-13-2011, 05:50 PM   #12
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Used to have mpg but as its all over the place its kinda meaningless for every day use so i replaced it with speed readout.
AVG MPG, resets after 10 hours of down time
*FWT, water temp
Old 04-13-2011, 07:35 PM   #13
rick996
rick996's Avatar
I was just playing around with my SGII adding gauges. Here are the gauges I added and the results:
FLV (Fuel Level) Is supposed to be % of tank left. Gets no reading at all so the UltraGauge makes no difference. I really would have liked that one.
HPR (Instantaneous Horsepower) works. Shows about 8 HP at idle. I'll check it out when I'm actually driving to see if it gives me useful info.
ERT (Engine Run Time) Shows time in minutes since you started the engine. Kind of useless. I was hoping it would show lifetime run time.
AIR (Ambient Air Temp) Works well. Showed 46 degrees F and that's what it is outside. FIA (Intake-Air-Temperature) which is a standard gauge showed a much higher temp as I was not moving.
PSI (Barometric Pressure) Shows pressure in PSI and I am used to inHG (inches of mercury) which is standard with barometers. Showed 14.2 PSI which is 28.91 in/Hg so you are close if you double it.
Old 04-13-2011, 07:39 PM   #14
rick996
rick996's Avatar
It varies constantly but my strategy is to generally try to keep MPG higher than AVG MPG.
Old 04-13-2011, 08:15 PM   #15
07 flint mica
Drives: 07 sedan.04 2500hd,10 mazda3
07 flint mica is offline   Reply With Quote
Old 04-18-2011, 12:56 AM   #16
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
1. Speedometer (Since the Yaris' center-mounted one is worse than useless.)
2. Tachometer (I do a lot of mountain driving, using engine braking extensively. Some of the grades I encounter in Colorado are up to 19%!)
3. Avg MPG.
4. Coolant Temperature (I get very nervous depending upon idiot lights.)
I'd really like to be able to include alternator voltage and GPH, too. Also horsepower, which is a custom X-gauge query I added to mine.
sbergman27 is offline   Reply With Quote
Old 04-18-2011, 01:17 AM   #17
sbergman27
sbergman27's Avatar
Important information should be in front of the driver. As long as there are warning chimes, buzzers, whatever, I suppose it might not be *so* bad to have oil pressure and coolant temperature warning lights way over in the center of the dash. And I can even deal with the times I've been surprised to suddenly notice that the last bar of the fuel gauge is "flashing fast" when I'm on the highway in the middle of nowhere. But that center-mounted speedometer is nothing short of criminal.
The whole "center-mounted" bit is a cost-saving measure, implemented so that no matter which side the steering wheel is on in a particular market, the instruments are equally, but not quite completely, unusable. I think I determined, at one point, that the parallax of the speedo at 70 is about 4 mph.
The managers who approved that should be assigned mandatory community service time trying to bring Fukushima Daiichi under control, and given special radiation suits with all the warning indicators and gauges mounted on panels just in front of their right ears.
-Steve
Old 04-18-2011, 08:31 AM   #18
rick996
rick996's Avatar
When I found more gauges I wanted to see I stopped using the scanguage as a speedometer. It didn't even take a day go get used to.
I had MPG, Avg MPG, MPH and Cost for the day.
Now I have MPG, Avg MPG, HPR and LOD.
Autometer Phantom II gauges cali yaris Items for Sale by private party 4 11-09-2009 07:45 PM
Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder bieniman DIY / Maintenance / Service 4 05-19-2009 11:40 PM
My new gauges set up PETERPOOP Cosmetic Modifications (Exterior/Interior) 30 04-19-2009 08:50 PM
Mechanical vs Electric Gauges? PETERPOOP Forced Induction Forum 13 04-06-2009 01:25 AM
WTB: Boost Gauges Teruyume Items for Sale by private party 4 11-12-2006 02:42 PM
