Old 03-01-2011, 01:59 AM   #217
RedRide
RedRide's Avatar
Offset explained:
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old 03-01-2011, 04:25 AM   #218
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
also bolt pattern. make sure they are 4x100.
Old 03-01-2011, 04:45 AM   #219
Yari5Love
Drives: 08 Polar White LB
Quick answer: No, they won't fit.
Thank You!!!
Yari5Love is offline   Reply With Quote
Old 03-03-2011, 05:30 AM   #220
Midnight Drifter
Going Retro
Drives: '09 Tacoma | '90 Tercel
Just a quickie here, can going from factory size (180-60-15) to a slightly taller sidewall (185-65-15) be afforded without rubbing?
Midnight Drifter is offline   Reply With Quote
Old 03-03-2011, 01:38 PM   #221
kimona
kimona's Avatar
Drives: 2014 White VITZ
You should be fine with 185/65/15's. Post a pic if you decide to go that way.
Old 03-04-2011, 06:53 AM   #222
Midnight Drifter
Going Retro
Will do, the tires I have in mind have a very unique feature to them. Won't see any pictures for months though, still gotta wear out the stocks. ;)
Old 03-04-2011, 01:48 PM   #223
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Question
Tell us please!
(o:
CLA 250, 4MATIC
Old 03-06-2011, 03:48 PM   #224
glhsracer
Drives: 2008 Sedan MT
Great thread, lots of good information. I have an 08 Yaris Sedan, I believe it has 185-50-15, car is not here so I can't walk out to check. I have a new set of 205-50-15 in my garage, do you think these would these be too much for the Yaris? I think it would look better with a little more tire but don't want to get too carried away. Any advice would be helpful, thanks.
Glhsracer
glhsracer is offline   Reply With Quote
Old 03-06-2011, 06:35 PM   #225
derickveliz2
Exclamation
Glhsracer
In winter I run with 205/50/15, they look great if your car is lowered, performance is awesome. The Diameter is less than OEM (smaller tire) speedometer will read about 3% faster than actual.
D.
CLA 250, 4MATIC
Old 03-11-2011, 05:02 AM   #226
Midnight Drifter
Going Retro
Tell us please!
(o:
You'll just have to see it when it's time to change my tires :)
Old 03-15-2011, 02:52 PM   #227
derickveliz2
FYI....
My snow tires didn't like the negative camber )o: on rear end.
D.
CLA 250, 4MATIC
Old 04-03-2011, 07:52 PM   #228
SKurj
Drives: 09 Yaris 3dr HB, BRZ
Ok would like to know which offset you would recommend... Looking at a 2008, 3 dr with Tein springs, Kosei 17x7 with 205 40 17, the rims come in 2 offsets, 38 and 42. Which would be the wiser choice?
Thanks
SKurj is offline   Reply With Quote
Old 04-03-2011, 08:00 PM   #229
kimona
kimona's Avatar
Thanks
I would recommend ET42. With the drop and 205mm rubber, ET42 works best up front.
Old 04-03-2011, 10:22 PM   #230
Murtaza_murti
Drives: Toyota Belta
How much would my Belta's fuel consumption be affected by adding 185/65/R15 after the stock 165/70/R14.
Murtaza_murti is offline   Reply With Quote
Old 04-29-2011, 10:53 PM   #231
MitchReeves2967
Drives: 2010 Toyota Yaris Sedan
I don't understand what this stuff means. I'm not the most knowledgable about this stuff.
MitchReeves2967 is offline   Reply With Quote
Old 04-30-2011, 10:11 AM   #232
kimona
kimona's Avatar
What information are you looking for?
Old 04-30-2011, 02:04 PM   #233
MitchReeves2967
Like what all goes into choosing wheels?
Old 05-04-2011, 06:11 PM   #234
SKurj
Ok still trying to make up my mind....
How about 17x7.5 ET40 rear and ET45 front with 205/40/17?
With Tien springs... on a 3dr hatch
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 98 02-18-2024 06:45 AM
