Old 11-23-2010, 11:30 AM   #199
kimona
kimona's Avatar
Drives: 2014 White VITZ
14x6, ET40-45, 205/60/14
Old 11-23-2010, 02:18 PM   #200
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
i know some people are pushing 225mm tires on a 6" rim... but the side wall looks like its at a 45 degree angle off the rim.. also thats stock suspension.. my race rims are 15x7 with a 40ET. i run 225/50/15 khumo v700.. if i turn the steering wheel all the way left or right, the tires rub on the chassis
Old 11-23-2010, 06:06 PM   #201
Midnight Drifter
Going Retro
Drives: '09 Tacoma | '90 Tercel
Stupid question here, what's ET? ._.
Midnight Drifter is offline   Reply With Quote
Old 11-23-2010, 07:34 PM   #202
kimona
kimona's Avatar
Offset.
Old 11-27-2010, 12:35 AM   #203
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
What about a 15x7 +27 offset with a 195/55/15 tire.I'm already lowered about 1.7". Is it possible? How much negative camber and fender pulling and rolling are we talking about?
marlondog is offline   Reply With Quote
Old 12-20-2010, 07:58 PM   #204
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
This is what I'm aiming for
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 02-13-2011, 01:13 PM   #205
henry33
Drives: yaris1.33
is it ok to put 6.5J R15 ET (offset 35) on the yaris hatchback ? I do not know if the offset is good since originally there was Et40
thank you
henry33 is offline   Reply With Quote
Old 02-13-2011, 03:11 PM   #206
kimona
kimona's Avatar
^^ Which size tyres will you run?
Old 02-13-2011, 05:21 PM   #207
henry33
Drives: yaris1.33
I will be using 185/60 r15 and originally there was ET45
Old 02-13-2011, 06:33 PM   #208
kimona
kimona's Avatar
^^You'll be fine with that set-up.
Old 02-14-2011, 03:09 AM   #209
henry33
Drives: yaris1.33
ok so I will buy those wheels most probably ;)
thank you
Old 02-14-2011, 07:28 AM   #210
PumpkinSteve
PumpkinSteve's Avatar
Drives: Yaris SR 1.8
I have 16 x 6.5 ET45 and I'm wondering if I can fit 205/50/R16 if my car is lowered by 30-35mm? I have the 1.8 Yaris which already has the steering lock reduced as standard to stop the 17" wheels rubbing, so it might be okay with this model?
PumpkinSteve is offline   Reply With Quote
Old 02-28-2011, 05:45 PM   #211
Yari5Love
Drives: 08 Polar White LB
Quick question thinking about buying some wheels but wasn't sure if they would fit my 08'Liftback the wheels are 4x100 bolt pattern&13x7 with a 15 offset anyone know if they'll fit without making any adjustments to the car? my car isnt lowered or anything just stock. please no flaming just a question I need answered. thanks
Yari5Love is offline   Reply With Quote
Old 02-28-2011, 05:58 PM   #212
kimona
kimona's Avatar
Quick answer: No, they won't fit.
Old 02-28-2011, 11:17 PM   #213
piranha0522
Drives: '06 Yaris
hmm..would this fit ok?
So I found a nice set of rims in my area.
They are 16" 4 bolt with tires 205, 45, 16. These would fit fine right?
I have an '06 5dr liftback.
What does everyone mean when they say offset? I still haven't figured that out.
Thanks!
piranha0522 is offline   Reply With Quote
Old 03-01-2011, 12:59 AM   #214
RedRide
RedRide's Avatar
Offset explained:
http://www.tirerack.com/wheels/tech/...jsp?techid=101
Old 03-01-2011, 03:25 AM   #215
ilikerice
ilikerice's Avatar
also bolt pattern. make sure they are 4x100.
Old 03-01-2011, 03:45 AM   #216
Yari5Love
Thank You!!!
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
