#199 |
14x6, ET40-45, 205/60/14
#200 |
i know some people are pushing 225mm tires on a 6" rim... but the side wall looks like its at a 45 degree angle off the rim.. also thats stock suspension.. my race rims are 15x7 with a 40ET. i run 225/50/15 khumo v700.. if i turn the steering wheel all the way left or right, the tires rub on the chassis
#201 |
Going Retro
Drives: '09 Tacoma | '90 Tercel Join Date: Aug 2010
#202 |
Offset.
#203 |
Shut your fricken suck!!!
What about a 15x7 +27 offset with a 195/55/15 tire.I'm already lowered about 1.7". Is it possible? How much negative camber and fender pulling and rolling are we talking about?
#204 | |
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
I Drive a 129whp Yaris ;) |
#205 |
![]() ![]() ![]() Drives: yaris1.33 Join Date: Jul 2010
is it ok to put 6.5J R15 ET (offset 35) on the yaris hatchback ? I do not know if the offset is good since originally there was Et40
thank you |
#206 |
^^ Which size tyres will you run?
#207 |
I will be using 185/60 r15 and originally there was ET45
#208 |
^^You'll be fine with that set-up.
#209 |
ok so I will buy those wheels most probably ;)
thank you |
#210 |
![]() ![]() Drives: Yaris SR 1.8 Join Date: Sep 2010
I have 16 x 6.5 ET45 and I'm wondering if I can fit 205/50/R16 if my car is lowered by 30-35mm? I have the 1.8 Yaris which already has the steering lock reduced as standard to stop the 17" wheels rubbing, so it might be okay with this model?
#211 |
![]() Drives: 08 Polar White LB Join Date: Mar 2010
Quick question thinking about buying some wheels but wasn't sure if they would fit my 08'Liftback the wheels are 4x100 bolt pattern&13x7 with a 15 offset anyone know if they'll fit without making any adjustments to the car? my car isnt lowered or anything just stock. please no flaming just a question I need answered. thanks
#212 | |
#213 |
![]() Drives: '06 Yaris Join Date: Feb 2011
hmm..would this fit ok?
So I found a nice set of rims in my area.
They are 16" 4 bolt with tires 205, 45, 16. These would fit fine right? I have an '06 5dr liftback. What does everyone mean when they say offset? I still haven't figured that out. Thanks! |
#214 |
Offset explained:
http://www.tirerack.com/wheels/tech/...jsp?techid=101 |
#215 |
also bolt pattern. make sure they are 4x100.
#216 |
| Tamago's guide to ultimate yaris handling | Tamago | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 99 | 01-25-2026 12:51 PM |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
