Old 05-07-2011, 09:25 PM   #19
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
my bumper project cost me aroun $75 including the spare bumper. you really should be able to take care of it yourself.
-sandpaper (a few different grits)
-fiberglass resin jelly (don't even need the fiber)
-paint (maybe primer, maybe not)
if you do want it to be perfect, get a shop to do it. if you are alright with saving a little green and it looking alrightish, do it yourself. you should be fine. realize that you need the smallest container of the stuff since you are just sticking stuff together.
there again, if you want it perfect, the shop works.
Old 05-08-2011, 03:39 PM   #20
YarisSedan
Drives: 08 Yaris Sedan
http://www.youtube.com/watch?v=NuA6d49Z7Rc
You can try to melt the plastic back together first and use a light amount of bodyfiller.
Old 05-10-2011, 11:08 AM   #21
wildmongoose26
wildmongoose26's Avatar
Drives: 09 5dr Yaris
The bondo wont hold it all together. (Yes I'm being lazy and not reading the whole thing) You should probably put some sort of support on the back side of the lip area. The bondo wont hold it rigid enough to keep it from flexing and eventually cracking the bondo. Put some fiberglass or get a can of kitty hair and place it on the back side of the lip to get the shape and support back in it. Then strip the paint in the area, then you can bondo body fill the SMALL gaps left. Sand, prep, sand, paint, sand, clear, buff that area and you should be good. Or take it to a bodyshop and have them fix it and blend it for a few hundred bucks.
Old 05-10-2011, 02:28 PM   #22
.Kevin.
I ain't even mad
.Kevin.'s Avatar
I've decided to go with a fibreglass repair kit from homehardware,
My plan is to use this and pile it up abit under the lip where it is un visible. Solid it up then masking tape with newspaper off the area sand it down and fill the cracks a little bit then sand that bastard down, prime, paint, clearcoat, soak it, wash on wax it and call it a day.
Sounds about right no?
Old 05-10-2011, 02:52 PM   #23
wildmongoose26
Dont wax it right away. The paint has to cure and release some of the moisture. If you wax too quickly it could cause issues in the paint finish
Old 05-10-2011, 03:07 PM   #24
BEEF
BEEF's Avatar
the only thing is that fiberglass resin is runny like water or very thin sap. I tried using regular fiberglass with my project and couldn't get it to conform long enough to cure.
you may want to look into the resin jelly.
http://www.amazon.com/Bondo-Fibergla...5050812&sr=8-1
it is much easier to work with and comes with all the stuff you are talking about doing. you just have to wait for it to ship versus going and getting it.
Old 05-10-2011, 03:11 PM   #25
wildmongoose26
Or http://www.amazon.com/Kitty-Hair-Fil...sr=1-1-catcorr
The Kitty Hair I stated before. You just pull it out, put some hardner in it and go to work. Take some hot glue and dowls to get the bumper in the shape you want. do the kitty hair on the backside of the lip where no one will se eit and you can pack it in there enough to give it good support. You can also use kitty hair on the cracks if there are any and sand it down.
WTB> DESPERATE .Kevin. Willing to Buy by private party 12 11-20-2010 07:51 PM
Sound Bars? Equalizers? what is it called ---Desperate for 1 click.mine General Yaris / Vitz Discussion 4 03-27-2009 12:05 AM
2005 Toyota Corv/Echo, I'm desperate, so CHEAP FDwannabe Cars for Sale by private party 4 11-17-2008 08:26 PM
