Old 05-07-2011, 02:40 AM   #1
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Desperate help
How the hell can I fix this without paying 1K$ + for a totally new bumper to be placed on.
Old 05-07-2011, 02:43 AM   #2
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Woops, here are the photos sorry guys. I really need help dammit.
Was thinking of just going to an auto shop and having them make some sort of metal plate to cover the front lip or something.
File Type: jpg 225296_10150233819814083_641929082_8703816_8115396_n.jpg (44.7 KB, 106 views)
Old 05-07-2011, 02:52 AM   #3
LA Yaris
Yaris323
LA Yaris's Avatar
bondo body filler will work
Old 05-07-2011, 03:13 AM   #4
.Kevin.
I ain't even mad
.Kevin.'s Avatar
What is this you speak of and how will the results be? Also where can I acquire this?
Thanks for your help man
Old 05-07-2011, 03:19 AM   #5
LA Yaris
Yaris323
LA Yaris's Avatar
How to Use Bondo Body Filler
Bondo is the most popular method of repairing a damaged body panel. It is an inexpensive alternative to having the panel professionally repaired and is easy to use. Bondo consists of two chemicals: the filler and the hardener. The materials are mixed together and then applied to the surface. Once dry, the material can be sanded to the desired shape and, if desired, painted.
Sand all paint off of the damaged area with sandpaper.
2
Wipe the damaged area down with a tack rag to remove any sanding deposits, which can prevent the Bondo from properly adhering to the surface.
3
Mix the Bondo filler with the Bondo hardener, using the plastic putty knife supplied with the Bondo kit. The filler is the gray material in the can, while the hardener is the red material in the tube. Use 1/4 tube of hardener for every 1/4 can of filler. Mix the materials together until they turn a uniform salmon color.
4
Apply the mixed Bondo material to the damaged area with the plastic putty knife. Swipe the material from one side of the damaged area to the other side of the area in a single motion while pressing the material into the area. Pressing the Bondo into the surface will ensure that the material fills small irregularities.
5
Allow 10 to 15 minutes to pass for the Bondo to dry.
6
Sand the Bondo down with sandpaper until it conforms to the body panel.
Old 05-07-2011, 03:41 AM   #6
.Kevin.
I ain't even mad
.Kevin.'s Avatar
so this can be done in a day? Gonna youtube vids of this I've never done anything to my car not sure if I have the balls to.
Old 05-07-2011, 03:45 AM   #7
LA Yaris
Yaris323
LA Yaris's Avatar
Yes it's ok to do in the day, don't worry you'll be fine. Just take your time do not rush it. YouTube will help you see how it works..
Good Luck !
Old 05-07-2011, 03:47 AM   #8
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Thanks I'll try, where can I buy it and any idea on its cost?
Also still taking pointers, anyone know how much a shop charges just to do bondo themselves?
Old 05-07-2011, 04:09 AM   #9
LA Yaris
Yaris323
LA Yaris's Avatar
You can Buy bondo at any auto shop, the price is from $15-$30.
If you take it to a shop it shoulden't be more the $300. I had a bad crack on my car too. took it to a shop to get it fix I paid $170.
Old 05-07-2011, 02:43 PM   #10
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Have you ever tried this stuff yourself is my only question.
Old 05-07-2011, 04:33 PM   #11
LA Yaris
Yaris323
LA Yaris's Avatar
Yes I have on my old car.
Old 05-07-2011, 05:54 PM   #12
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Looked for it at Crappy tire, Wally world, and some other random places to no avail.. Dammit.
Will have to see what an auto shop quotes it
Old 05-07-2011, 06:36 PM   #13
Bondo will not work on cracked plastic. Bondo is used for filling in dents.
Old 05-07-2011, 06:41 PM   #14
.Kevin.
I ain't even mad
.Kevin.'s Avatar
So you saying I have to get a new bumper? Or can an auto shop do anything to fix my current one>?
Old 05-07-2011, 07:05 PM   #15
SKurj
Drives: 09 Yaris 3dr HB, BRZ
Think some places advertise plastic repairs.. another option might be fiberglass...
Visit a body shop and ask if they can repair it.
Looks like you are so low, this won't be the last time...
SKurj is offline   Reply With Quote
Old 05-07-2011, 07:26 PM   #16
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I used fiberglass resin jelly to fill in my bumper once. it took a really long time but it looked nice and it was the first time (technically second) I ever played with the stuff.
http://www.youtube.com/watch?v=4n6iNOxl5PA
at the very end, I used bondo just to smoothe it out. the area I covered was tons bigger than yours. I think you can do it in a day. just make sure to get the resin jelly (it is like grout and doesn't really drip) order it online if you can't find it locally. you won't need much at all. make sure to also have some paint. duplicolor seems to work well (also available online).
you can do this. save some money (you'll need it for the NOX setup ;))
Old 05-07-2011, 08:18 PM   #17
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Is the bumper mounted on the car in that pic?
Old 05-07-2011, 08:44 PM   #18
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Aslong as it gets fixed to look normal I am fine. Also I was rollin on 14's at the time when it happened, winter had ended but snow turned to ice since it was inside a pot hole - thought it was snow in the middle of the road plowed it and the rest is history I still have the plastic piece thats missing that actually broke off. Now it is on 15 inch wheels, and in this photo my bumper is actually clearing a sidewalk so it has a good 6 inches will be dropping maybe an inch to make it an equal five (atm its stock height)
Nice to see you are following and supporting my NOS idea! Well I know we have dupli color here, but I am scared shitless to do anything to my car myself and by the sounds of it so far if it costs 150ish dollars to fix, I won't be spending much less getting all the supplies for this self repair so I may aswell have a shop do it.
Refer to my first quote sir.
WTB> DESPERATE .Kevin. Willing to Buy by private party 12 11-20-2010 07:51 PM
Sound Bars? Equalizers? what is it called ---Desperate for 1 click.mine General Yaris / Vitz Discussion 4 03-27-2009 12:05 AM
2005 Toyota Corv/Echo, I'm desperate, so CHEAP FDwannabe Cars for Sale by private party 4 11-17-2008 08:26 PM
