Old 06-07-2011, 09:08 PM   #199
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I just wrapped mine. What I thought was a 1 man, 5 minute job tuned into a 2 man, 15 minute job. I used 1/2 in. wrap instead, it fit nicely when it was straight, but at the bends it was a pain. Some of the bends aren't fully wrapped, I couldn't get it all the way around. C'est le vie.
EDIT: And yes, JUST in time for summer!
Old 06-19-2011, 05:57 PM   #200
p123456789
Drives: 07 lb jeep tj
Am I the only one who thinks the yaris a/c works very well even down here the florida humidity?
p123456789 is offline   Reply With Quote
Old 06-23-2011, 08:52 PM   #201
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Hey guys, I just bought the stuff to do this with.
I got the insulation and the zip-ties, and now I need to get the tape to reflect the heat.
I've got a few concerns though...
What if moisture gets under the insulation? The pipe won't rust will it? I'm rather worried about the long-term affects.
I'll give it a whirl anyway seeing as how nobody has said anything bad about it.
Black_griffin6 is offline   Reply With Quote
Old 10-15-2011, 01:29 PM   #202
poorsh2
Drives: 2008 yaris hb
ss Zip ties
I put the insulation on with ss "zip ties" you can get them at harbor freight
poorsh2 is offline   Reply With Quote
Old 06-29-2012, 07:02 PM   #203
Em_
Drives: 2007 Yaris
i tried it and it melted , it's a fire hazard from my point of view even with reflecting tape,
if the car burns the insurance won't cover
the only solution would be exhaust insulating fabric
Em_ is offline   Reply With Quote
Old 06-30-2012, 11:00 PM   #204
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
Originally Posted by LugNut View Post
There's definitely more cooling capacity, but at the cost of fuel economy. Before I could barely detect a difference in lugging of the engine with the compressor engaged. But now there's a big AC load on the engine.
Is this true? I can't see how insulating a line would actually affect the load of the compressor. It should simply be reducing the lost cooling in the pipes.
teddy is offline   Reply With Quote
Old 07-01-2012, 09:20 AM   #205
PatrickJohnson
Drives: 2008 Yaris LB
Then you did it wrong. I've had mine on for years now, with no issues.
PatrickJohnson is offline   Reply With Quote
Old 07-01-2012, 10:09 AM   #206
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
here's an example of what not to use and what you should've used...
http://www.thesolarshop.eu/acatalog/...nsulation.html
Old 07-01-2012, 12:06 PM   #207
CoryM
Drives: 2009 5-door, 5-speed
First time seeing this topic. My concern would be that you are removing some of the engineering that was so carefully put into the A/C system. By this I mean that the liquid coming out of the compressor needs to evaporate completely. Some of which is expected to be done in that line (not where you want it, but they probably allow for the loss). If it stays liquid the compressor tries to do the impossible and compress the incompressible (liquid). This would explain the extra load noticed when the a/c is on. Basically the compressor pistons are in mild hydraulic lock (and hating it). Compressor life will be reduced.
Probably less likely in ridiculously hot/arid places where the evaporator will deal with it. But in humid areas, or more sane temperatures, you may run into this.
Cheers.
Old 07-02-2012, 06:15 PM   #208
schume
Drives: 2010 Yaris LB
You could be right and they might have engineered the A/C system to compensate for the loss due to uninsulated suction lines. I insulated my line and I only use the A/C when it's hot, so I'm sure I'm getting good evaporation. Maybe if I ran the A/C on cold below a certain temperature, I could start having problems.
The accumulator is there to prevent any liquid from reentering the compressor, but I guess we'll wait and see if there are a lot of A/C failures reported in the future :)
schume is offline   Reply With Quote
Old 07-03-2012, 12:35 PM   #209
CoryM
Do you have the a/c disabled during defrost?
As I said, I am not certain that you would end up w/ liquid. It's certainly possible, and hearing that guys are noticing more load on the engine makes it seem more probable.
Cheers.
Old 07-05-2012, 06:20 PM   #210
RedRide
RedRide's Avatar
One must consider that the AC sys is designed to work under all extremes of ambient temps.
So, I don't see how adding a bit of insulation to simulate lower ambient temps will be detrimental.
Old 07-07-2012, 05:06 PM   #211
schume
Oh yeah! I hated that "feature" and was happy to disable it :)
I agree and I personally don't think it's a big deal either (or else I wouldn't have done the mod)
Old 07-11-2012, 03:18 PM   #212
swidd
Drives: Yaris HB
I've had mine insulated for 3 years or something now, and left it on during cold season, and have never restricted my use of A/C when cold outside. No problems at all, and the high temperature resistant tape holds up nicely.
swidd is offline   Reply With Quote
Old 08-13-2012, 03:50 AM   #213
yours_falsely
yours_falsely's Avatar
Drives: 2008 Yaris sedan
So now that some time has passed since it's first been tried, what I'm taking from this is that there don't seem to be any long term negative effects. Correct?
yours_falsely is offline   Reply With Quote
Old 08-13-2012, 11:40 AM   #214
PatrickJohnson
I'm at 2 or 3 years, and no problems here.
Old 04-20-2013, 07:17 PM   #215
yarisitis
yarisitis's Avatar
For those of you who first did this mod in 2009, how's it holding up? Any negative effects on the AC system? Foam melting?
yarisitis is offline   Reply With Quote
Old 04-20-2013, 07:54 PM   #216
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I did this a year or two ago. The insulation right above the exhaust manifold has melted slightly, otherwise it's help up fine. Didn't REALLY notice a big difference though, but every little bit counts!
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
