Old 07-10-2011, 08:27 PM   #73
Focus_Sh1ft
Focus_Sh1ft's Avatar
^ That's exactly what I was going to do. What size fitting did you use? I'm hoping 1/4 NPT will be enough.
Old 07-10-2011, 08:39 PM   #74
Brian
Brian's Avatar
-8AN (1/2") 90° bulkhead fitting for the oil return. -4AN (1/4") for the feed line. I ran the feed line from the factory oil pressure sensor underneath the intake manifold.
Old 07-10-2011, 11:16 PM   #75
Focus_Sh1ft
Yeah I'm still using the -8 AN line, but the only fittings I was able to find (for tapping the block) was 1/2" flare to 1/4" NPT. Hopefully that won't restrict flow too much.
Old 07-10-2011, 11:39 PM   #76
Brian
Brian's Avatar
I ordered all my fittings from Summit. Here's the one I'm using
http://www.summitracing.com/parts/EAR-983308ERL/
http://www.summitracing.com/parts/EAR-992408ERL/
Old 07-10-2011, 11:47 PM   #77
Focus_Sh1ft
Thanks Brian. I honestly think I'm just gonna order those to put my mind at ease. Are you using the return line that came with the Zage kit?
Old 07-11-2011, 12:07 AM   #78
Brian
Brian's Avatar
I ordered all new lines and fittings and made my own. If you want I can post or send you the links for everything I used.
Old 07-11-2011, 01:13 AM   #79
posting would be great. I'd like to include all of that with the kits in the future.
Old 07-11-2011, 02:39 PM   #80
Focus_Sh1ft
I'd actually like to know too. It's turning out to be a PITA to find a length of hose that isn't completely overkill.
Old 07-11-2011, 02:58 PM   #81
Brian
Brian's Avatar
I'll post up the info when I get home. I ordered 6' stainless braided hoses and just cut them to the length I wanted. I have the sizes for all the fittings just because I wanted blue ones.
Old 07-11-2011, 09:36 PM   #82
Brian
Brian's Avatar
Here is the list of parts you will need if you want to make your own oil feed and return lines. I have attached links to Jegs and Summit so you can see what the parts look like.
OIL RETURN LINE
(you can still use the 45 degree fitting and reducer from the Zage kit but I will list them just in case you want to replace them as I did)
3/8" NPT to 45° -8AN flare
http://www.jegs.com/i/JEGS-Performan...oductId=752558
(2x) -8AN hose end fitting
http://www.jegs.com/i/JEGS-Performan...oductId=757777
-8AN stainless steel braided hose (you can get away with 3' but I would get 6' just in case you mess up)
http://www.jegs.com/i/JEGS-Performan...oductId=752578
-8AN 90 degree bulkhead fitting
http://www.jegs.com/i/JEGS-Performan...oductId=858285
-8AN bulkhead fitting nuts
http://www.jegs.com/i/JEGS-Performan...00293/10002/-1
OIL FEED LINE
(I removed to factory oil pressure sensor and used that location for my oil feed line. You will NOT get a CEL from removing the sensor.)
-4AN to 10mm x 1.0 straight fitting
http://www.summitracing.com/parts/RUS-670500/
-4AN male to -4AN female fitting with 1/8 NPT gauge port (this is where you're aftermarket oil pressure gauge connects to)
http://www.summitracing.com/parts/EAR-100201ERL/
-4AN stainless steel braided line (6' or 10' to be safe)
(2x) -4AN straight hose end fittings
On the fitting with the 1/8 NPT port it will be a very tight fit but it will work. You may want to add a 45 degree 1/8 NPT female to 1/8 NPT male fitting for more clearance.
http://www.summitracing.com/parts/FRA-491501/
Old 07-11-2011, 11:46 PM   #83
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Right, but you wanna make sure you have some indicator on oil pressure, be it a gauge or a dummy light somewhere. It would suck to do all that work installing a turbo and have an oil leak or a line that pops you don't know about and cook the motor.
Old 07-11-2011, 11:54 PM   #84
Brian
Brian's Avatar
I mentioned that on the second part listed for the oil feed line. I know how important the gauge is. Without it I wouldn't have known about my low oil pressure problem.
Old 07-19-2011, 02:49 PM   #85
Focus_Sh1ft
New oil line installed. Not only has blow by seemed to stop, but I no longer smell oil burning. I should have done this from the start... Highly recommended for anyone who buys a Zage kit. Plus, it gave me a reason to buy a dremel - which I've been wanting for awhile now.
Old 07-19-2011, 04:08 PM   #86
Brian
Brian's Avatar
I had to use my dremel too. A lot easier than a drill which is almost impossible to get in that tight of a space.
Old 07-19-2011, 11:25 PM   #87
Focus_Sh1ft
Actually, I used a 90 degree fitting for the drill since I had it, but I was definitely thinking about using the dremel beforehand. I had to use it to cut the hose - every other method didn't give me a clean enough cut.
For anyone in the future who needs to assemble their own hose - cut the hose (using electric tape), slip the compression part on and slide it down to where you want to make the actual cut. Then you simply slide it back up the hose and thread the nipple in. I found it difficult to cut the hose, slide the compression part on, then thread the nipple by only using the original cut. The end begins to get frayed. Trust me, I'm an expert at this now lol.
Again, thanks for the help Brian.
Old 07-19-2011, 11:32 PM   #88
Brian
Brian's Avatar
I forgot to mention how to assemble the hoses. Glad you figured it out though. Maybe you can include a hose assembly DIY and the fitting sizes into the install DIY.
Old 07-20-2011, 05:47 PM   #89
Focus_Sh1ft
Guide updated.
I re-plumbed my coolant lines today. Originally I had them in parallel, but I changed them to series instead.
Old 07-21-2011, 01:37 AM   #90
Pur_Blu
Pur_Blu's Avatar
Drives: NCVC craziest
Send a message via AIM to Pur_Blu Send a message via Yahoo to Pur_Blu
Have u had a chance to get your car on the dyno to check the numbers?? Even with your current tuning. Im curious to see what kinda numbers the kit puts out. Glad to see you've gone boosted for so long now with no major problems if at all
Pur_Blu is offline   Reply With Quote
Turbo kits!! djgab101 Forced Induction Forum 26 03-09-2015 03:24 PM
Turbo kit Brainstorming Gideon Forced Induction Forum 16 04-19-2009 12:54 AM
