Old 11-17-2008, 03:00 AM   #1
djgab101
djgab101's Avatar
Drives: toyota yaris
Turbo kits!!
on ebay i found 3 turbo yaris 1nzfe kits each claim they can make more than 170hp!!!
has anyone installed one of theses turbo kits!!!
http://cgi.ebay.com.au/Toyota-Yaris-...3A1|240%3A1318
http://cgi.ebay.com/ebaymotors/JDMS-...mZ120325105228
http://cgi.ebay.com.au/Turbo-kit-for...3286.m20.l1116
are these turbo kits worthy or not!! quality or shit!!!!
djgab101 is offline   Reply With Quote
Old 11-17-2008, 06:11 AM   #2
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
The first one is Zage, not really sure on how it performs. Some say its turbos are bad others say someone should try it. The other 2 I haven't heard of but the only way we will know if it works if is someone spends their money and updates us of the status.
Its a Chao!!!
Old 11-17-2008, 08:03 AM   #3
revoturbo
revoturbo's Avatar
Drives: yaris
The 1st & 3rd pictures =Zage..
I already try on my yaris & other friends.. they works great.. on A/T show 200Km/h
multimakmurperformance.com
revoturbo is offline   Reply With Quote
Old 11-17-2008, 10:00 AM   #4
TheRealEnth
Beast
Ur saying it works fine? Completely fine with how much hp to the wheels?
Its a Chao!!!
Old 11-17-2008, 10:03 AM   #5
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
2nd setup doesn't even give you a mani, but yeah he does have the Zage kit, but the mod list seems skeptical for the power output...or the zage turbos can only push 5psi without exploding... Now if he got the turbo rebalanced that would be a different story with that kit... because i hear that was the only major issue on the civic kit..
and if you can contact them directly they sell it for $2000
Old 11-17-2008, 11:01 AM   #6
BUY IT BUY IT BUY IT
Old 11-17-2008, 11:03 AM   #7
TheRealEnth
Beast
garm why dont u buy one and place it on your so much stronger engine ready to take it =p. Ill use ur current turbo while you do it <3
Its a Chao!!!
Old 11-17-2008, 07:18 PM   #8
revoturbo
revoturbo's Avatar
Drives: yaris
my friend at rev engineering did zage turbo on civic 1,8 . & works great but not as full power , they still problem on ecu. but with low boost .35 bar works great on civic. than without turbo :)
Old 11-17-2008, 09:31 PM   #9
at3GG
at3GG's Avatar
Drives: 07 metmet LB
F5 CAI, MR axleback, MR Header, NST SSK.
Full Exhaust wrap, AT3 Custom SSK
Konig Heliums 15x6.5 Black
Tanabe Df210's
at3GG is offline   Reply With Quote
Old 11-19-2008, 07:42 AM   #10
djgab101
djgab101's Avatar
u said that to other ppl who were intrested in this kit but u said it is shit and will blow up!!!
are u just saying this so we can buy it and prove it's shit!!!
Old 11-19-2008, 07:51 AM   #11
djgab101
djgab101's Avatar
I have changed my mine and decieded to buy a good turbo!!!
so i was going to get this one!!
Old 11-19-2008, 07:59 AM   #12
TheRealEnth
Beast
cool, tell us how it works out and if it actually gets 160-180
Its a Chao!!!
Old 11-19-2008, 08:15 AM   #13
djgab101
djgab101's Avatar
well the problem with that is yes i will get the kit...... when i cna afford it but yes when i do i will get before nad after dyno results and photos!!!
Old 11-19-2008, 08:47 AM   #14
"fuel management required", that's the tricky part
Old 11-19-2008, 08:51 AM   #15
Nexus1155
Drives: Audi
Garm says most parts on the turbotoyota kit do not fit at all...
Old 11-19-2008, 11:52 AM   #16
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
FYI
That turbo kit does not actually exists!
Turbo Toyotas is not producing it any more. Sure if you contact them they will tell you they'll get you one. After a 6-12 month wait.
I don't think the ZAGE turbo kit is shi**t like others have said. Is just a budget kit. You have to take it for what it is. It probably won't last long if you are planning to abuse it.
On the other hand we have reports of a lot of people using the kit in other countries with no major problems reported.
Sure, you can not compare a Taiwan made turbo charger against a Garret unit and it probbaly won't last as long as a Garret but you get what you pay for.
If you end up blowing the seals of the turbo aster only one year... then you can go and have it replaced with a high end unit.
What else could go wrong with this kit? A crack on the manifold? Unlikely since is a cast iron piece.
I say go for it! How bad could it be!
Old 11-19-2008, 06:10 PM   #17
revoturbo
revoturbo's Avatar
Drives: yaris
Originally Posted by CASTREX View Post
FYI
I already use ZAGE turbo kit on my own Yaris 1,5L. they works great.
afew month ago in Indonesia yaris show off, 10 of them use Turbo kit & 5 of them by Zage Turbo kit, they works great on The right Hand! The most important is Piggy back tuning (dastek unichip type Q)+ extra injector .
some of my friend already use yaris- zage turbo kit for 1year (last november 2007) Top speed 205Km/h. (on A/T).
& my yaris reach 180Km/H easy!
no problem on water temp etc... they works great if you get right good mechanic..
my own yaris , zage turbo kit, extra injector, Piggy back dastek unichip type Q+ with turbo module , Gizzmo IBC, earl's oil cooler, boost controller, + turbo timer. I got 175HP,
Zage turbo kit works great on left hand drive, AT . (down pipe model plug & play on left hand drive, if right hand drive we must modify down pipe like mine)
if you need more info: teddyrev@yahoo.co.id
Old 11-19-2008, 07:04 PM   #18
at3GG
at3GG's Avatar
only problem is the management. I'm sure there would be quite a few more turbo yarii on here if that problem could get solved.
Tanabe Df210's
NST NonStopTuning Short Shift Kits NonStopTuning NonStopTuning 2 11-11-2008 07:39 PM
delayed turbo project... joey1320 Forced Induction Forum 8 09-26-2007 11:18 PM
TURBO DIY... forpinks Forced Induction Forum 33 09-06-2007 02:03 AM
NCP 91 RS 1500 TRD Turbo ????? ramishrrr General Yaris / Vitz Discussion 3 01-15-2007 04:51 PM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
