Old 07-12-2011, 06:50 AM   #1
chexmix
Drives: scion xb
help installing foglight!!
hey people... i need help installing the foglights... got it from peterpoop.. he got it from microimage.... yay free stickers.. lol.. anyways following the pdf file on microimage...im kinda confuse on where the switch wires go to..on the
on the new instructions.. on step 6.. i want to follow "B"... but its sounds like it just tapping the red wire to pin 3 and tapping the green wire to pin 13.. but on the old insturctions... it tells me to take out pin 3 from d4 connector and plug the green wire from the switch from there.. and take the old pin 3 and connect it to the red wire from the switch... but the thing is im having a hard time taking out the pin 3.. can i just cut and splice? or does anyone have an easy route to take it out.. lmk which directions to go with.. thanks
chexmix is offline   Reply With Quote
Old 07-13-2011, 01:34 AM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Not sure what kind of wires you got, you may want to post up all of your switches and wires.
I don't have the relay, so my setup is different.
Old 07-13-2011, 02:07 AM   #3
chexmix
Drives: scion xb
i have 3 wires coming out from the switch.. black is ground... then i got green and red... but not really sure where to connect those...
Old 07-13-2011, 03:48 AM   #4
yariseggvvti
Drives: Yaris Hatchieback
the easiest way and save time is connect the wire to the parking light. when you turn on the parking light, the fog light is on. In the way you dont have to connect a switch or run those wire in and out.
yariseggvvti is offline   Reply With Quote
Old 07-13-2011, 10:06 AM   #5
If your harness only has three wires coming out of the switch, then it is yet another variant of the switch. Can you take the cover off the the switch and take a picture of both sides of the circuit board, with the connector plugged in?
Old 07-13-2011, 10:58 AM   #6
Scott, that is the old kit, peterpoop bought that a while ago I think. So at least it's not a "current" variant. Ray might be helpful with this too.
Old 07-13-2011, 11:17 AM   #7
Ahhh - That's a relief. It would still be handy to get a pic of either side of that version and that way I can update that doc for both for the part in regards to not having the light on when the car is off.
Old 07-13-2011, 10:28 PM   #8
chexmix
Drives: scion xb
which wire would i connect to the parking light? any pic?
Old 07-13-2011, 10:28 PM   #9
chexmix
Drives: scion xb
lemme take a pic.. ill post later
Old 07-13-2011, 10:52 PM   #10
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Did Poop include the relay? If you just want a straight hookup, maybe I can help you over the weekend. Easier if you post all the wiring and CTScott can solve it for you. He's da man!
Old 07-14-2011, 04:08 AM   #11
chexmix
Drives: scion xb
yeah get the relay.. all works when i jump pin 3 and 4... but i need to connect the switch... or if theres a way to jump certain pin to make it work without the swtch... but heres some pics that i promise...
Old 07-14-2011, 05:24 PM   #12
OK - So from the pics, you do have the same one as what is documented in my updated PDF.
Pulling the pins from the OEM connector is not necessary. In the original doc is was written that way for those who did not want to cut or splice their factory wires.
For you to do option "B" in the new doc you just tap the outside red wire to pin 3 and the green to 13.
Old 07-17-2011, 06:38 AM   #13
Strider
Drives: 2010 Blaze Blue 4-door Hatch
Okay so I am in the same boat/place with the install as chexmix.
1) from the switch there are 4 wires, but the two reds are spliced together under the plastic flex conduit. So there is no outside red wire and at the end of the spliced together red wire, there is a gray plastic cylidrical connector of some sort. Are we suppose to de-splice the two reds and extend them out for the new steps 6 & 7? And when connecting to pin 3 & 13 we cut the current wires and splice into them (solder the wires together) I assume?
2) Also where would you recommend mounting the switch in a '10 4-door HB? I wanted it in front of the e-brake lever where there are 3 empty spots (there is a door lock switch in one of the four) but the switch is too small and sits too deep.
.... or is there a newer switch with the right wirng and size?
Thanks Guys.
Strider is offline   Reply With Quote
Old 07-17-2011, 07:49 AM   #14
Thanks Guys.
1) You do need to separate all four wires in the fog light harness. For the 3 and 3 connections, you don't need to cut the factory wires. You can either use tap splice connectors or you can strip some insulation off and solder the wires.
2) The switch with its sleeve should actually be a little too big for the knockouts in the center console. You have to shave a bit of the hole to make it fit. I believe that even the OEM Toyota switch requires that to be done.
Old 07-17-2011, 08:42 AM   #15
Strider
1) Thanks, got that one sorted out now.
2) Nope, it is too small / hole is too big. Doesn't sit up high enough. I'll take a couple of pictures.
Old 07-19-2011, 01:55 AM   #16
chexmix
Drives: scion xb
once i connect the red wire from the switch to pin 3.. the switch light turns on.... is there anyway to stop that.. i dont want to kill the battery.. when i continue the install and put the green wire to pin 13... it works great.. just the light on the switch bothers me.. i think i read somewhere on somebody elses post... that they had same problem
Old 07-19-2011, 04:09 AM   #17
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
just cut the LED out of the switch
Old 07-19-2011, 08:09 AM   #18
You clipped the correct resistor (in your picture above), which like Ray suggested with clipping the LED, eliminates the light that always stays on and separates the lighting from the switching.
Where did you connect the lighting wires to? Did you connect them to the shift illumination circuit per the updated instructions below?
2006-2011 Yaris Aftermarket Fog Light Switch Wiring.pdf
HELP!!, HOW TO INSTALL FOGLIGHT YARIS SEDAN?? shangapol DIY / Maintenance / Service 12 11-28-2012 12:53 PM
Stock/aftermarket Foglight Question? Yaris4L1fe Cosmetic Modifications (Exterior/Interior) 19 06-23-2011 06:47 AM
Question about installing projector fog lights Terra DIY / Maintenance / Service 3 06-15-2011 02:29 PM
FS: Foglight Switch including Relay AzNguy Items for Sale by private party 4 10-19-2009 11:04 PM
WTB: 06 Hatch Foglight Covers (non foglight) hasher22 Willing to Buy by private party 2 06-24-2009 12:35 AM
