#14 | |
1) You do need to separate all four wires in the fog light harness. For the 3 and 3 connections, you don't need to cut the factory wires. You can either use tap splice connectors or you can strip some insulation off and solder the wires. 2) The switch with its sleeve should actually be a little too big for the knockouts in the center console. You have to shave a bit of the hole to make it fit. I believe that even the OEM Toyota switch requires that to be done.
| HELP!!, HOW TO INSTALL FOGLIGHT YARIS SEDAN?? | shangapol | DIY / Maintenance / Service | 12 | 11-28-2012 12:53 PM |
| Stock/aftermarket Foglight Question? | Yaris4L1fe | Cosmetic Modifications (Exterior/Interior) | 19 | 06-23-2011 06:47 AM |
| Question about installing projector fog lights | Terra | DIY / Maintenance / Service | 3 | 06-15-2011 02:29 PM |
| FS: Foglight Switch including Relay | AzNguy | Items for Sale by private party | 4 | 10-19-2009 11:04 PM |
| WTB: 06 Hatch Foglight Covers (non foglight) | hasher22 | Willing to Buy by private party | 2 | 06-24-2009 12:35 AM |
