Old 07-08-2011, 02:37 AM   #1369
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Exclamation
A-pillar update!
D.
CLA 250, 4MATIC
Old 07-08-2011, 03:53 AM   #1370
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
I connected my I-Touch for the first time ina while, for some reason it sounded better than my regular MP3 player, i hardly put cd's in anymore although CD's give you far better sound. I need to find a good program that will convert audio files without losing alot of SQ.
Maybe somebody can chime in.
Congrats on the i Pad ! One question if you play a movie on the i Pad will you get surround sound straight off the USB or would you have to run an Audio / video cable like this ?
Old 07-09-2011, 01:00 AM   #1371
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Music file conversion? Goldwave.
― Thomas Paine
Old 07-09-2011, 02:11 AM   #1372
derickveliz2
Wink
Having heard the L6SE before in a "tuned" vehicle (a 3x MECA world champ vehicle), one almost doesn't need a woofer...seriously...Dave had his Camry pushing his L6SE's down to 25 Hz. They had great attack and decay, great presence and the definite ability to play low. He had two 12" woofer IB loaded in the trunk. They only came alive around 30 Hz and below.
in my setup I have more power and much more control than even that championship vehicle I'm alluding to. This means good things!
I'm not going to be a champ, that is not my intention, but this is exactly where I'm going to... if I can get my L6s properly installed and tuned I only need a little sub-woofer in the front!
D.
CLA 250, 4MATIC
Old 07-09-2011, 10:19 PM   #1373
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Hey D,
How do you have the thread-serts installed in the baffle for the mids? Just screwed in?
― Thomas Paine
Old 07-10-2011, 12:58 AM   #1374
derickveliz2
Red face
Maybe somebody can chime in. [/IMG]
I didn't know about "Goldwave" so I've been using free software:
D.
CLA 250, 4MATIC
Old 07-10-2011, 01:09 AM   #1375
sqcomp
Roadrunner Jr.
sqcomp's Avatar
http://www.goldwave.com/
― Thomas Paine
Old 07-10-2011, 01:12 AM   #1376
derickveliz2
Thumbs up
Hey D,
For this I really had to go back into my R/C skills... (not a big science, but it's simple and it works)
1.- mark precisely all 4 holes.
2.- use a tiny drill bit to center the thread-serts
3.- use a bigger drill bit but still smaller than the thread sert
4.- screw in the thread sert
5.- unscrew the tread sert
6.- apply CA + accelerator into the MDF hole
7.- re-screw thread sert
8.- apply CA + accelerator to the outside of the thread sert
I know, maybe sounds complicated but the rings for the HL-70s don't leave space for errors/mistakes, it's just to small. Like you can see in the photos the thread serts exposed on one side... final en result... rock solid.
D.
CLA 250, 4MATIC
Old 07-10-2011, 01:13 AM   #1377
derickveliz2
Today I test fit the a-pillars... like a glove! fit is perfect!
D.
CLA 250, 4MATIC
Old 07-10-2011, 01:26 AM   #1378
derickveliz2
My brother came to visit us, I took him for a ride on my Yaris, well I gave him the keys for the ride of his life! and this is what happen later:
We start pulling out the drive way and a couple of blocks away he tells me "This is a very quiet car, feels very solid and I can barely hear or feel the engine" He has a 2008 Subaru Legacy.
Then I turn on the P-99 (no a-pillars, no Mids, tweeters on cup-holders) and he was speech less... then I explained to him about Time Alignment, front stage... and he was thrilled! I told him how much better the sound is when the Mids are in action. He just couldn't believe it.
Another point for the Yaris and one more day of making me feel good about it... all this work and time on my car. Makes me feel proud of my self. (o:
D.
CLA 250, 4MATIC
Old 07-10-2011, 03:50 AM   #1379
_S7V7N_
_S7V7N_'s Avatar
Congrats bro !
Old 07-10-2011, 09:43 AM   #1380
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I was hoping you CA'd those thread-serts in.
good news on the test drive!
― Thomas Paine
Old 07-11-2011, 12:38 AM   #1381
derickveliz2
Thumbs up
I love CA+Accelerator
got used to it when building r/c airplanes.
D.
CLA 250, 4MATIC
Old 07-11-2011, 11:36 PM   #1382
sqcomp
Roadrunner Jr.
sqcomp's Avatar
More spurring for D to follow:
...Of course I didn't take the opportunity to take a picture with the grills over the speakers. What I have to do now is to find a NON-stainless steel machine screw (preferably a flat headed security type screw) so that I only need to use magnets on the grill's underside to attach them to the kick.
That'll probably happen sometime this week or early next.
What should be noted about these grills is that these are for daily driving and use. I have some "show" grills being made right now. I'll place those on...during shows obviously. These that are made above are a little bit of router work, some sanding, painting, stapling, and gluing. It's a fun afternoon project really.
― Thomas Paine
Old 07-11-2011, 11:50 PM   #1383
derickveliz2
Very nice, do you have a picture looking at the back of the enclosures?
D.
CLA 250, 4MATIC
Old 07-12-2011, 03:13 AM   #1384
sqcomp
Roadrunner Jr.
sqcomp's Avatar
The back huh?
You're trying to see if I have them open like the last pods? If that's the case, no I don't. I've got the opening on the bottom that leads down into/through the subframe holes in the floorboard.
^This is actually the side of the pod. I can tell because the little hole right there is used to bolt the pod into the car where the wiring bundles behind the kicks go.
It doesn't look like I have any direct pics of the back. I can take some if you'd like.
^You can see the hole I was referring to through the grill cloth...
^There's also this one too...
You can see with that last one that the pod's glassing is VERY thick. When you rap or knock on the pod, it's pretty much a dead thud or impact. It's not hollow at all. I'd liken it to the same sound when you hit a stone wall. There's just THAT sound...that nope, it's not moving sound. All the interior and edges of said interior of the pods have been coated with long hair. It's simply rock solid.
I'd estimate that each of the kicks unloaded weights at least 10 lbs.
― Thomas Paine
Old 07-13-2011, 08:09 PM   #1385
derickveliz2
Very nice Sqcomp,
Has HAT come up with a formula to calculate the area for venting? when I did my first pods (Spheres) some one at DIYMA wrote that the vents should be at least 1/3 of the cone area, what are the Legatia's cooking recipe for this scenario?
D. Ps... why did you do only 1 pair of kick panels? lol
CLA 250, 4MATIC
Old 07-14-2011, 07:19 PM   #1386
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Why only one pair of Yaris kicks? No one else has the nuts to do kicks like me.
He he...J/K D!
― Thomas Paine
