![]() Drives: 2012 Yaris HB LE Join Date: Jul 2011
Help with fog light installation
I follow this instruction (see attached)and after all done...fail. The fog swich ligh is on and off but seem like no power to the fog lights. Can someone help? I have exactly fog light kit like the author.
1.5 or 2.5 both=0-60 in 8
Does the foglight indicator on the Instrument Panel come on? Do you hear a click when you turn on the switch?
nope the fog light indicator on the instrument panel doesn't come on. No click. What am I missing? I double check all wiring many times and give up
Try connecting the Pin#2 as shown on your attachement on connector D4, if the lights come on then the problem is with the switch wiring.
Sorry, connect pin#2 (as shown on your attachment ) to the car ground.
ok what exactly that do? YOu mean this?>
That pin#2 was accoding to page 6 of the file you attached here, but according to above (which is the correct numbering) ground the wire in pin#3 (second from the left, top row).
what exact that does anyway? I thought that is the signal or turn on the power for the fogs...there is one ground from the switch already hook up. I will give it a shot and see how it goes.
Pin#3 is the the ground wire to the relay switch, if your lights turn on then it means you are good with the lights, lights wiring and relay.
no cigar...after I ground the pin#3 the light from the fog switch is on when I turn on my headlights but when I push to turn on the fog the light on switch turn off. Also I just found out my left signals are not working...where is the fuse for that? May I blew the fuse somehow..I checked the bulbs front and back they look fine...can\t find the fuse for the signal lights. :(
#11 | |
damn...check that 10a haz fuse and it looks ok...only the left signal doesn't work the right side is ok. When I flick left it make a really fast sound like tick tick tick...I even checked the fuse Tail 10A under the driver left leg in the car and the fuse is ok too...freaking frustrated
If it makes a fast tick tick then either the front or rear bulb is blown.
#14 | |
Also, if you can snap pics of your connections in the under-hood fuse panel and at the stalk, we might be able to make more sense out of what is going on.
still no luck...freakin yaris...I even take the bulbs from the right side put them on the left both front and back and all I hear is tick tick tick fast but no light...hopefully I didnt mess up any wiring while install that fog lights...I am beyond frustrating right now...
#16 | |
damn somehow I just remove the haz fuse and replace it with the spare one now the signal works...my next problem solving is still the fog lights...:(
Hang on - How did you connect the fogs under the hood? You don't have the two fog light wires installed in the connector next to the fuse puller?
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| Fog Light Installation | chrisj | Cosmetic Modifications (Exterior/Interior) | 39 | 03-12-2011 12:08 PM |
| Has anyone tried taping into the parking lights for fog light installation (safe?) | YarisSedan | DIY / Maintenance / Service | 14 | 03-20-2010 05:49 AM |
| 2009 HB fog light installation | rbell | DIY / Maintenance / Service | 3 | 06-17-2009 10:16 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 11:42 AM |
