Old 09-24-2011, 04:29 PM   #1
vdubs4ever
vdubs4ever's Avatar
Drives: Red '08 3 Door
DRL wires
Does anyone know where the wires for the drls are, I have an '08 HB and would like to change the DRLs from the main headlight bulb to that small bulb on the inboard side of the actual headlight. I know for the Mk3 Jetta I had my friend moved an wire on the switch itself. Can anyone help me.
Mors Certa, Hora Incerta, Memento Vivere
vdubs4ever is offline   Reply With Quote
Old 09-25-2011, 08:17 AM   #2
The large blue wire in pin 1 of the DRL module is the output. You can clip that wire, cap the harness side and connect the module side to whatever bulb you want to be your DRL.
Old 09-25-2011, 10:51 PM   #3
MadMax
MadMax's Avatar
You're 08 HB has DRLs? Is that unique to Pennsylvania?
Old 09-25-2011, 10:56 PM   #4
DRLs were part of the "cold weather" package.
Old 10-02-2011, 10:27 AM   #5
vdubs4ever
vdubs4ever's Avatar
where can I find the drl module
Old 10-02-2011, 10:49 AM   #6
Between the steering column and the radio.
Old 10-02-2011, 12:05 PM   #7
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
If you take both panels off from under the steering column you'll find the DRL tucked away right up against the center column (where the radio is) on the bottom right hand side of the panel you just took off.
Scion XD LED mirror install pics aplenty enviri DIY / Maintenance / Service 76 07-21-2019 02:10 PM
Ultimate Turbo Pre-Install Guide Focus_Sh1ft Forced Induction Forum 7 09-14-2017 03:28 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
Hid bi xenon problem need to keep drl due to fogs marcus Cosmetic Modifications (Exterior/Interior) 4 06-20-2010 12:01 PM
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 06:37 PM
