Old 07-11-2011, 06:17 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
Can i Bring MAF closer to intake manifold??
thinking of cutting my air intake and bring the maf closer to the intake manifold...of course only due to bigger and longer cone filter.. would this cause issue starting car or maf reading air mixture??....anyone?? thanks!
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 07-11-2011, 08:12 PM   #2
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
It's no big deal but if your trying to go faster leave it where its. Thats the sweet spot. Why do you want to cut your intake? Is it your stock intake? If so then why buy a new one. There fun to install and they look cool and they work great.
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 07-11-2011, 08:15 PM   #3
^ He's running a PRM Short Ram. Same one I have as can be seen in my garage.
I have seen someone with a setup that has the MAF sitting very, very close to the throttle body. I don't think you'll have an issue, but why do you want to do it? Also, with the vaccum nipple sitting right beside the TB coupler, there is no pipe really available to cut to make it shorter. Only thing you can do is cut a section out of the middle and splice it back together. And again, why? What is wrong with the existing PRM filter?
Old 07-11-2011, 08:59 PM   #4
marcus
toyota
marcus's Avatar
thinking of switching to a larger cone wont fit unless i cut on the throttle part of the intake which will make the maf closer to the manifold..but i read somewhere that this does slow you down..??
Old 07-12-2011, 12:35 PM   #5
KSIbucky
KSIbucky's Avatar
A larger cone wont improve performance by much .009 hp
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 07-12-2011, 12:54 PM   #6
I was at a dyno session where, using the same tube, the PRM filter was compared to an AEM cone filter. PRM made more power.
Old 07-12-2011, 01:52 PM   #7
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
^ does the PRM make the most power intake?
what am i saying...i'll just fab up my own intake when i feel like it
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-13-2011, 10:24 PM   #8
Cap
Drives: Toyota
Intakes are not about More Air Flow to make 'Power'.
Intakes work so well because the 'Incorrect Placement' of the MAF in the Intake Messes with the ECU's Calculations and Causes it to Accidently give you more Ignition Advance..
Another Side Effect of the Incorrect Air Flow Calculation is the ECU is Forced to Correct the Fuel Mixture by adding to the Long Term Fuel Trim.. and the WOT will be leaner ( Motors are Usually too Rich a WOT and Need a little Fuel Pulled.. For the Cat )..
Cap
Cap is offline   Reply With Quote
Old 07-13-2011, 11:51 PM   #9
marcus
toyota
marcus's Avatar
i guess im keeping the set up..its more complex than i thought...now on to the next project..
Old 10-17-2011, 09:48 PM   #10
samuraivince
samuraivince's Avatar
Drives: 08 Yaris hatchback
what if you sneak in more air after the MAF senor? would that do anything?
samuraivince is offline   Reply With Quote
Old 10-17-2011, 10:10 PM   #11
Yury
Yury's Avatar
Drives: 2008 5 Door Liftback Auto
^ a man made vacuum leak...interesting :)
1999 Honda Prelude Base 5 speed (summer driver)
Yury is offline   Reply With Quote
Old 10-17-2011, 10:15 PM   #12
YarisSedan
Drives: 08 Yaris Sedan
Will set a check engine light for system too lean bank 1.
Old 10-17-2011, 10:29 PM   #13
samuraivince
i see, thats out of the ? then...... thanks!
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 08:05 PM
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 12:58 PM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 09:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-14-2008 12:26 AM
Intake Systems Decision Maker.. Blenjar Performance Modifications 25 09-15-2007 11:07 PM
