Old 04-09-2010, 03:04 PM   #19
Jerkratt
Jerkratt's Avatar
ok i found these
http://www.xtralights.com/replacemen...itesingle.aspx
REALLY EXPENSIVE if anyone can help with other sites that would be great cause 2 of my halos are out atm
"It hurts more when its wet"
Old 04-17-2010, 06:56 PM   #20
cfeng
Drives: Yaris 2010 Liftback
would 2008 aftermarket headlights work on a 2010 yaris?
cfeng is offline   Reply With Quote
Old 04-18-2010, 05:22 AM   #21
nuno11
nuno11's Avatar
Drives: Yaris Sport 2009 Hatchback
2009-up Yaris HB/LB headlights assembly are not the same as the 2008-down, the shape or design is different.
2008 - Down Headlight assembly. (thanks to PeterPoop for the image )
2009 - Up Headlight assembly. (thanks to 808_Yaris for the image )
...was thinking of doing a retrofit with a single prjector/angel eyes though i really am a big fan of dual projector lights .
--[ nobody beats me but me! ]--
nuno11 is offline   Reply With Quote
Old 04-19-2010, 04:28 AM   #22
cfeng
thanks for the clarification nuno
Old 04-19-2010, 04:30 AM   #23
cfeng
im hoping that they start making aftermarket head/tail lights for the 2009+ yaris
Old 04-25-2010, 10:07 AM   #24
nuno11
nuno11's Avatar
yep..i was hoping too. I can do the retrofit myself if only i have the proper tools and space.
Old 04-25-2010, 03:30 PM   #25
Jerkratt
Jerkratt's Avatar
Originally Posted by Jerkratt View Post
ok i found these
anyone?
Old 05-16-2010, 07:02 AM   #26
thatboyjer
thatboyjer's Avatar
Drives: 5spd 2007 Yaris LB
Great DIY! doesn't seem like too hard of a job. I got some dual halo's on my accord and was wondering about the ones they had for the Yaris. I want to get my hands on a set without those dinky (imo) 3 lights near the top
99.9% of what goes on in my mind at work/school/home
[Debadged] [Tanabe DF210] [Limo Tint][17" Fondmetal Wheels] [Pioneer HU]
--:: Wishlist, PM me ::--
[SSK (WTB)] [Black Sand Pearl Eyelids (WTB)]
thatboyjer is offline   Reply With Quote
Old 12-13-2010, 12:20 AM   #27
yaris873
yaris873's Avatar
Drives: freedom white hatchback 2008
Hello.Pls help! is projector headlight for 3door 2008 HB compatible with 5door 2008 HB? Thank you.
yaris873 is offline   Reply With Quote
Old 12-13-2010, 07:41 AM   #28
big lo
big lo's Avatar
Drives: 2007 VIOS
Good work, DIY was clear and the out come awesome.
Old 01-10-2011, 01:52 PM   #29
Samc1985
Drives: 07 yaris
That's what I'm wondering too.
Any one?
Samc1985 is offline   Reply With Quote
Old 01-25-2011, 08:37 AM   #30
nOmi_89
Drives: 2007 Toyota Yaris
um guys help me out i'm stuck :( and i can't figure out what the problem is :(
last week i installed these Halo LED Projectors Headlamp...
and my halo Rings are constantly On...whether i switch of the headlights...
i just figured out that when ever i connect the wires with low beam bulbs the rings just cant go off....and when i disconnect the wires from low beams...it works perfectly fine as it should...
what should i do :( help me plzzz
nOmi_89 is offline   Reply With Quote
Old 06-16-2011, 01:20 AM   #31
jackay
Drives: Toyota Yaris 3dr :)
Hey guys,
Anyone know where I could find the connector that PETEAUSSI used to connect into the park light socket? Looks like a parking light dummy
anyone?
jackay is offline   Reply With Quote
Old 09-17-2011, 10:12 PM   #32
Kluak
Drives: 2007 Yaris sedan charcoal
I am liking the dual halos, i want to see somebody to the retro fit of a single halo.
i will probably end up doing the single halo/retro fit. i want to keep the oem plastic
Kluak is offline   Reply With Quote
Old 11-13-2011, 08:16 PM   #33
dreamindiesel
Drives: 2007 3 Door
I realize this is old, but I just picked up some from ipex motoring and installed them with ease. They look good but the angel eyes on drivers side wont go totally off and plus no way to adjust the projector light (low beam). It points to the trees. :-(
Thanks, Shannon
dreamindiesel is offline   Reply With Quote
Old 01-13-2012, 12:50 AM   #34
Red Raider
Red Raider's Avatar
Drives: 08 Yaris 3DR
Thanks, Shannon
Having exact same problem..no idea what to do
Red Raider is offline   Reply With Quote
Old 01-13-2012, 01:28 AM   #35
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
It is liek that. The only way to change the cutoff kicking up so high is to completely dismantle the headlights and change the cutoff INSIDE The projector.. and that's quite a bit of work.
Old 01-22-2012, 08:03 AM   #36
birdman
Drives: '08 Blazing Blue Yaris LB
Finally there are directions for installing these kits that we all can understand. Now I can get a set and be able to install them without issues. I've always liked these. Thanks for the great write up.
birdman is offline   Reply With Quote
Poll - LED Eyebrows for the Yaris - Vote Yea or Nay Violin Cosmetic Modifications (Exterior/Interior) 63 04-29-2007 01:26 AM
