#37 |
My Face Is Ridiculous
Drives: 2010 Toyota Yaris 3dr LB Join Date: Dec 2011
except that it's annoying on a nice new(ish) car.
I took it out for lunch and noticed it doing the same thing, but this time it didn't get really low and vibrate the cabin. must have been the really cold weather this morning. |
#38 |
![]() Drives: 1nz-fe Join Date: Apr 2009
I'm pretty sure this problem is caused by the MAF sensor sitting too close to the throttle body on the aftermarket intakes. At idle RPM it does not have the proper airflow through the sensor (it measures less air than it should).
#39 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan 2010 "shadow" Join Date: Mar 2010
would spraying with carb cleaner the intake of the TB just after the MAF would help?
may need someone to rev it up while spraying it |
| WR Secret Weapon Intake Dyno Tested.. | WRLEO | Performance Modifications | 70 | 05-17-2007 03:00 PM |
