Old 04-26-2012, 07:27 PM   #19
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I'll be happy to let you know how this little experiment goes. Many 4 cylinder stock exhaust manifolds employ the tri-y design for more bottom end so it's a tried and true principle. Here's a longer header that illustrates the principle more clearly...
...and a brief explanation:
"Tri-Y's consist of a four-into-two-into-one design, with four primary pipes paired into two slightly larger secondary pipes before reaching a single collector. One advantage of this design is that the increasing pipe diameter broadens the torque curve, providing higher torque throughout the low- and mid-rpm range than a similar four-into-one style header. Headers work especially well for RV's and trucks in which lots of low-rpm torque is important.
The principle behind tri-Y design is that the most effective port separation occurs by pairing the cylinders that are firing farthest apart, in other words 180 distributor degrees (or a complete crankshaft revolution) apart."
I understand that just installing a header won't make a huge difference, I've always been interested in exhaust designs so it's fun to tinker around with them. And as far as I know, Weapon R is the only manufacturer who makes a tri y for Yaris'.
Old 04-26-2012, 09:46 PM   #20
tooter
play every day
tooter's Avatar
Oh oh... looks like I'm already in trouble.
The 2012 header doesn't look anything like the earlier models...
Man, I sure hope the header is at least pointing in the right direction.
Old 04-27-2012, 01:59 AM   #21
hellstang947
Drives: 2007 Toyota Yaris
I hope you can fit it in there. I eagerly await your review
hellstang947 is offline   Reply With Quote
Old 04-27-2012, 02:54 AM   #22
tooter
play every day
tooter's Avatar
I'm really counting on the head pipe being the same as all the others...
...because it would mean that even though the 2012 header is of a totally different construction, the relationship of the engine exhaust ports to the head pipe remain the same as the prior years. From what I can tell so far, it's going to be a really tight fit, and jolly good fun trying to get all the bolts back in!
Old 08-24-2013, 05:13 AM   #23
ldinkinsjr
Drives: 2009 toyota yaris sedan
TOOTER, still waiting on FE or MPG results on the header.
ldinkinsjr is offline   Reply With Quote
Newbie with an exhaust leak on his '06 Yaris ToYarta DIY / Maintenance / Service 49 01-03-2019 12:50 PM
Enkei's and Dunlops + Medalion Touring Exhaust 2manywheels Items for Sale by private party 40 04-04-2011 05:01 PM
))) new TS exhaust question ((( aucorium Performance Modifications 4 03-29-2010 01:21 AM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
