Old 03-27-2010, 07:44 PM   #1
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
))) new TS exhaust question (((
hey guys
i did a cat back exhaust on my TS , 57mm pipe all the way to the back , kept the OE resonator in , but got a megan racing rear exhaust muffler , car pulls alot stronger from the bottom , but seems to be lacking on top a little now , should i have gone smaller ? like 50mm ? as the OEM pipe size is approx 45mm from the factory , i feel from pull away its much stronger , but seems to fade out at high speeds a little , will a smaller exhaust pipe work better ? should i give the ECU time to learn first ? should i go smaller to 52mm mabye ? or 50mm ?
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 03-27-2010, 09:42 PM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
57mm is too wide unless you are FI. 50mm would be closer to what is recommended for NA setups.
Old 03-28-2010, 04:46 AM   #3
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
thx for the reply buddy, FI ?
yeah , i know i have a 1800cc TS , but the 57mm seems to be to big , OEM is 45mm from the center resonator , you think 50mm will be ok ? will i loose power ? should i rather put the OEM piping back with my aftermarket rear muffler only?
JDMtuner
www.jdmtuner.co.za
Old 03-28-2010, 05:59 PM   #4
tk-421
tk-421's Avatar
Drives: 5D-07-LB
FI = Forced Induction (i.e. turbo)
50mm is fine. Not sure how going any wider will help matters.
Old 03-29-2010, 01:21 AM   #5
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
i checked on the net , all the 1zzge motors aftermarket exhaust sizes are 60.5 mm , the 1zzge is na , and runs a little more KW , but less torque , so then in theory the 57mm on my 1.8 should be ok ? or at very least , i should go down to 53mm ? as i see the 1.5 yaris has a 50mm sizing on its aftermarket axel back systems from places like greddy.
JDMtuner
www.jdmtuner.co.za
Megan exhaust question MGargano Performance Modifications 12 03-18-2014 03:23 PM
question about exhaust. wowitswil Performance Modifications 17 11-13-2009 03:18 PM
Quick Exhaust question... nickhjort Performance Modifications 22 05-22-2009 11:02 AM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
Exhaust Question MGargano Performance Modifications 12 04-18-2009 10:48 AM
