Old 05-01-2012, 05:22 PM   #1
superfly78209
Drives: 2010 Yaris 5 Dr Blue Grey
Gauge Cluster Swap Warranty?
Thinking about doing a gauge cluster swap to get a tachometer. Would the dealer be able to tell that my model Yaris did not come with a tach then assume I swapped the gauge cluster and thus end my existing warranty?
Megan Axle Back Exhaust
Pro Dry S Replacement Filter
superfly78209 is offline   Reply With Quote
Old 05-01-2012, 06:23 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Hmm. I would say that because you're using OEM parts, that it shouldn't be a problem. That said, I do not handle Toyota warranty claims, and can't promise anything.
Old 05-01-2012, 06:38 PM   #3
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I doubt they'd go that far. Even if they could make that determination, it is not grounds for voiding the entire warranty.
Old 05-03-2012, 01:19 PM   #4
superfly78209
Thanks for info. Hopefully that wouldn't be the case. Definitely thinking about getting one with a tach.
Old 05-03-2012, 02:00 PM   #5
The problem is that your mileage on the replacement one won't match your car's mileage, so the dealer can claim that you are messing with the ODO and therefore not honor your warranty.
If you get one, they take 2 minutes to swap out, so I would keep the original one on hand and swap it back if you are bringing the car in for service. That, or work with your dealer on installing the new one, so they can document the ODO discrepancy.
Old 05-03-2012, 04:26 PM   #6
superfly78209
Good Idea Scott. Did some research on the forums. Will an 2010 cluster sedan fit a hatch fyi? Also, what years are compatible with 2010 clusters. I'm guessing all of them? Thanks.
Old 05-03-2012, 04:31 PM   #7
Hatch and sedan cluster are not interchangeable. As far has model year compatibility, I believe any year will work.
Definitely have to work with dealer to document ODO discrepancy. Swapping in and out won't work as someone will wonder why your mileage never changes.
Old 05-03-2012, 06:19 PM   #8
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
I crossed this bridge a few years ago and came to the conclusion that the Europe Toyota dealers can get some nice digital clusters. I lost interest in the idea but if you can find a way to get the tach cluster, let us know.
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 05-03-2012, 06:26 PM   #9
Correct on the lack of interchangeability. As for years, any will work, but you need to match features (i.e. if you have ABS, then you need an ABS equipped cluster, if you 2010 has traction control, then you are limited to 2010 and 2011 clusters).
Old 05-03-2012, 06:57 PM   #10
Bethlehem-yaris
Black 3 door
Bethlehem-yaris's Avatar
Drives: 2011 3DR BLACK YARIS
If you have the dealer installs parts it WILL NOT void the warranty.
If I put anything on my car, with it being less then 1 year and just at 10k miles. I will need to have the dealer pretty much do everything. That's why for my spoiler I went back.
Bethlehem-yaris is offline   Reply With Quote
Old 05-06-2012, 01:01 AM   #11
superfly78209
Thanks for info. How do I find out if my Yari has traction control? If I don't match up features will they not work? Or I just wont get error messages
Old 05-06-2012, 08:43 PM   #12
Actually, all 2010's had it. If you use a cluster that from an older car without it, you will just lose the indicators for it.
HB GAUGE CLUSTER WITH RPM $125 TURBO YARIS Items for Sale by private party 17 12-12-2011 06:44 PM
Successful Gauge Cluster Swap kac Cosmetic Modifications (Exterior/Interior) 37 07-06-2010 08:05 PM
FS: Gauge Cluster from '09 LB- $150 MGargano Items for Sale by private party 14 10-05-2009 12:59 PM
Gauge Cluster Swap, other interior swap questions. Adrenalingirl_K In Car Entertainment + Electronics (audio / video / alarm) 4 04-09-2009 03:32 AM
