Old 06-30-2012, 06:34 PM   #145
In terms of prep, dyno it like you drive it for the most accurate result.
You might write down a few things to compare to future dynos, ambient air temp, humidity, tire pressure, what fuel is in the car, etc.
Old 06-30-2012, 08:47 PM   #146
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I will... just normal 87 gas 40 psi in the tires and no other changes so that the conditions will be as similar as possible between the two sets of runs.
Old 06-30-2012, 09:02 PM   #147
tooter
play every day
tooter's Avatar
Some pics with the air filter removed...
You can see how close the throttle body and MAF sensor are to the stack.
And heres a video of the engine running...
http://www.youtube.com/watch?v=JQt2uJ7PYfQ
There's not much intake noise even with the camera stuck up close. In the beginning the ECU was fishing around for an idle mixture trying to adjust to the open intake, but found its equilibrium by the end of the video.
Old 07-02-2012, 10:00 AM   #148
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
FWIW, I came across this today...
http://www.rhdjapan.com/trd-exhaust-...-corolla-51956
Old 07-02-2012, 10:04 AM   #149
^ wow.
TRD Exhaust Manifold Header IST bB Vitz Corolla
Was: $ 1,086.96 Sale: $ 869.57
Old 07-02-2012, 10:08 AM   #150
suckerface
#1 Lemming
suckerface's Avatar
They have some great stuff on there, but you're certainly paying a premium for it. Just a shot in the dark, but I'm guessing the MI prototype will come in well under $800, right?
Old 07-02-2012, 10:13 AM   #151
I think that's an exhaust manifold, not an intake manifold?
Old 07-02-2012, 10:17 AM   #152
suckerface
#1 Lemming
suckerface's Avatar
*facepalm*
I'll just be over here in the corner, continuing to observe.
Old 07-02-2012, 10:19 AM   #153
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Old 07-02-2012, 10:20 AM   #154
Old 07-02-2012, 10:20 AM   #155
but yeah.... less than $800.
Old 07-02-2012, 11:20 AM   #156
tooter
play every day
tooter's Avatar
Interesting...
Looks like they tried to make the runners as long as they could by rotating them 90 degrees counterclockwise around the axis of the exhaust exit...
What a deal... for just eight. Does that include free shipping? I'll take the Weapon R for two.
Old 07-02-2012, 02:27 PM   #157
Intake noise is really only apparent at WOT under load. Sitting still at idle generates nothing. Sitting still and punching the throttle only produces a brief sucking sound. Out on the road, WOT is what makes them growl, which btw, cannot be heard with anything but the oem exhaust installed.
Old 07-02-2012, 04:34 PM   #158
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
That TRD header would add some real nice JDM swag to the Yaris.
Old 07-02-2012, 04:42 PM   #159
tooter
play every day
tooter's Avatar
Yes, I found that out when I did some flat out runs on the freeway last week, in preparation for the dyno tune. Could hear a slight roaring sound over the exhaust at wide open throttle.
In normal driving it's just as quiet as the stock air box... which makes the little lady happy.
Old 07-02-2012, 04:46 PM   #160
tooter
play every day
tooter's Avatar
I think the Weapon R is much better looking...
...especially at 25% of the cost.
Old 07-03-2012, 06:06 PM   #161
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Ive been running a ram air duct into my air box with the opening in the foglight hole. Ive ran 3 tanks this way with no noticeable difference in mpg. Highway power maybe feels better?
Im thinking ill make my own proper CAI using the blox...i really like that and i think i can squeeze it in the bumper...i got hammers...
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-03-2012, 06:38 PM   #162
tooter
play every day
tooter's Avatar
I got hammers...
I was checking around on ebay and it appears that BLOX also makes a much smaller 4 inch diameter velocity stack filter...
You can tell the smaller filter diameter because it has almost no taper as compared to the 7.5 inch filter, but yet has the same black plastic end cap. The only unknown is the inlet diameter, but that could be determined simply by asking the seller. One negative... it's pricey at $77 including shipping.
edit: from checking around, that may actually be a 4 inch inlet filter and not useable on the Yaris. The seller could confirm whether the filter itself is 4 inch diameter, or the inlet is 4 inch diameter.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
