Old 07-18-2012, 11:49 AM   #253
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Here's closeups of the ports taken while it was being flipped over to finish off the bottom.
The machine ran at a very fine resolution making lots of passes so that the transitions are nice and smooth.
Old 07-18-2012, 01:00 PM   #254
3cyltrbo
Tooter for President???
anxiously awaiting the final piece and dyno results
Big ups and much respect (as Alli G would say)
Will
3cyltrbo is offline   Reply With Quote
Old 07-18-2012, 06:55 PM   #255
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Will you be polishing the insides?
Old 07-18-2012, 07:23 PM   #256
tooter
play every day
tooter's Avatar
Hey Cranky,
Hadn't even thought about that. But I doubt it, maybe just hit them with a little fine emery cloth since I'm not running a top fuel dragster.
Did you notice anything about the outside runner holes?
We didn't undercut them as it would have added even more cost to the job. You had mentioned that as an issue, and we took the easy way around it...
The inner edges of the outer runners go straight down the edge of the head with no inner ledge. I'll simply feather out the inside edge of the runner tubing with a Dremel since the affected area is so small.
You should be able to the same thing to yours with no problems.
Old 07-18-2012, 07:43 PM   #257
tooter
play every day
tooter's Avatar
Will
Thanks for your kind words, Will.
I don't expect much from the second dyno as the stock Toyota manifold is factory engineered to be highly specialized for the 1NZ-FE. Whereas I'm just adapting something to an unintended purpose.
The OEM manifold does have quite a large plenum area... and that's good.
...because while the Corolla manifold has larger runners, the plenum area is quite small. This helps to make the total volume of the manifolds more equal to each other.
When I get the new manifold assembled, I'm going to tape off one end of both manifolds and fill them both up with water. Then I'll pour each one out into a big measuring cup and log each volume just to see how close they are.
I get really curious about funny stuff like this...
Old 07-18-2012, 08:08 PM   #258
anomoly40
Depot Damager
Drives: '08 Liftback
Are you planning on annodizing that intake?
2008 Yaris Liftback -
Bought in '12 with 80k
Sold in '17 with 180k
Bought back in '20 with 270k
Currently collecting parts for the 2zr swap
anomoly40 is offline   Reply With Quote
Old 07-18-2012, 08:35 PM   #259
tooter
play every day
tooter's Avatar
No... but that's just my own personal preference. I don't much care for the shiny plastic "circus" look of anodized aluminium.
But something will definitely need to be done to "normalize" the appearance of a brand new machined intake flange and throttle body adaptor on a beat up 14 year old junkyard manifold!
I'm thinking more like sandblasting the whole thing (except for the milled gasket surfaces) so that all of the surfaces will assume the same aluminium color and texture. After that, I don't know. Right now, I'm focused on finding out if the damn thing works first.
Old 07-18-2012, 08:38 PM   #260
anomoly40
Depot Damager
Look into Dust annodizing. I play paintball often and there are some amazing things they can do with anno.
Also Type 3 Anno doesn't have the plasticy look to it. It also helps with Heat disapation.
Old 07-18-2012, 09:44 PM   #261
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Effing tits flange
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-18-2012, 10:06 PM   #262
tooter
play every day
tooter's Avatar
It actually ~could~ have had tits on it...
The CNC guy said that there's software with such fine image resolution that with the right bit, the machine could replicate the head on a quarter.
Old 07-18-2012, 10:20 PM   #263
anomoly40
Depot Damager
We have a 1/64" endmill at work. We ordered it by accident. Even crazier is that they make smaller ones.
Old 07-18-2012, 10:31 PM   #264
malibuguy
Obsessed with 1.5L
Out of boredom....guessing game at gains??
Im feeling lucky...+4whp...wtq...-6peak
-96 Tercel 4dr
Old 07-18-2012, 11:16 PM   #265
CrankyOldMan
Originally Posted by tooter View Post
Hey Cranky,
Interesting. I was wondering how you would get around that. I had also considered something like that but with additional metal being added (welded) to that edge on the inside to meet the rim of the runner. Looks like it's coming along nicely, still can't wait to see how it performs!
Old 07-18-2012, 11:45 PM   #266
tooter
play every day
tooter's Avatar
Hey, we should have a pool!
My guess will be -6 hp at the bottom, and +2 at the top.
Old 07-18-2012, 11:48 PM   #267
tooter
play every day
tooter's Avatar
Seeing how the adaptor actually turned out with such a small area with no ledge, it's really not much of an issue. I'll just knock the edge off from the inside.
Old 07-19-2012, 01:02 PM   #268
malibuguy
Obsessed with 1.5L
well whats determining bottom? its less confusing guessing at peaks
Malibuguy: +4whp -6wtq
Tooter: +2whp
-96 Tercel 4dr
Old 07-19-2012, 02:08 PM   #269
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Put me down for + 1,000 whp...I believe in you!
-Type 07 FFL-
My odometer 03/11
Old 07-19-2012, 02:10 PM   #270
Garm: -5 whp / -5 torque
Bonus for the CEL?
Shall MI donate the prize for the pool?
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
