#253 |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
Here's closeups of the ports taken while it was being flipped over to finish off the bottom.
![]() ![]() ![]() The machine ran at a very fine resolution making lots of passes so that the transitions are nice and smooth. |
#254 |
![]() ![]() ![]() Drives: MR2 Spyd/Type R/Yaris/Civic Si Join Date: Feb 2007
![]() . . . . . Tooter for President??? anxiously awaiting the final piece and dyno results Big ups and much respect (as Alli G would say) Will |
#255 |
2ZR swap. DO IT! Ask how!
Will you be polishing the insides?
#256 |
play every day
Hey Cranky,
![]() Hadn't even thought about that. But I doubt it, maybe just hit them with a little fine emery cloth since I'm not running a top fuel dragster. ![]() Did you notice anything about the outside runner holes? ![]() ![]() We didn't undercut them as it would have added even more cost to the job. You had mentioned that as an issue, and we took the easy way around it... ![]() The inner edges of the outer runners go straight down the edge of the head with no inner ledge. I'll simply feather out the inside edge of the runner tubing with a Dremel since the affected area is so small. You should be able to the same thing to yours with no problems. |
#257 | |
play every day
![]() I don't expect much from the second dyno as the stock Toyota manifold is factory engineered to be highly specialized for the 1NZ-FE. Whereas I'm just adapting something to an unintended purpose. The OEM manifold does have quite a large plenum area... and that's good. ![]() ...because while the Corolla manifold has larger runners, the plenum area is quite small. This helps to make the total volume of the manifolds more equal to each other. When I get the new manifold assembled, I'm going to tape off one end of both manifolds and fill them both up with water. Then I'll pour each one out into a big measuring cup and log each volume just to see how close they are. I get really curious about funny stuff like this...
#258 |
Depot Damager
Drives: '08 Liftback Join Date: Jul 2012
Are you planning on annodizing that intake?
2008 Yaris Liftback - Bought in '12 with 80k Sold in '17 with 180k Bought back in '20 with 270k Currently collecting parts for the 2zr swap |
#259 |
play every day
No... but that's just my own personal preference. I don't much care for the shiny plastic "circus" look of anodized aluminium.
But something will definitely need to be done to "normalize" the appearance of a brand new machined intake flange and throttle body adaptor on a beat up 14 year old junkyard manifold! ![]() I'm thinking more like sandblasting the whole thing (except for the milled gasket surfaces) so that all of the surfaces will assume the same aluminium color and texture. After that, I don't know. Right now, I'm focused on finding out if the damn thing works first. |
#260 |
Depot Damager
Look into Dust annodizing. I play paintball often and there are some amazing things they can do with anno.
Also Type 3 Anno doesn't have the plasticy look to it. It also helps with Heat disapation.
#261 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Effing tits flange
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#262 |
play every day
It actually ~could~ have had tits on it...
The CNC guy said that there's software with such fine image resolution that with the right bit, the machine could replicate the head on a quarter. |
#263 |
Depot Damager
We have a 1/64" endmill at work. We ordered it by accident. Even crazier is that they make smaller ones.
#264 |
Obsessed with 1.5L
Out of boredom....guessing game at gains??
Im feeling lucky...+4whp...wtq...-6peak
#265 | |
#266 |
play every day
#267 | |
play every day
#268 | |
Obsessed with 1.5L
Malibuguy: +4whp -6wtq Tooter: +2whp .. ... ....
#269 |
advocatus diaboli
Drives: 07 Yaris hatch Join Date: Mar 2011
Put me down for + 1,000 whp...I believe in you!
-Type 07 FFL- ![]() My odometer 03/11 http://i205.photobucket.com/albums/b...a/2843ed85.jpg |
#270 |
Garm: -5 whp / -5 torque
Bonus for the CEL? ![]() Shall MI donate the prize for the pool?
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
