#2647 |
Corporate Slave
Drives: 2010 Yaris YX aka "Cutie" Join Date: Oct 2011
saglit lang yan tol he he he
Si Vis Pacem Parabellum CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to. Keep your ride rockin and rollin |
#2648 | ||
![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Apr 2009
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter) Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way If everything seems under control, you`re just not going fast enough...
#2649 |
tanong ko lang. bakit kapag naka-idle ako lalo na sa traffic light... parang mainit na ang ibinubuga ng AC. pero once na mag1st gear ako lumalamig na? di kaya dala lang ng panahon?
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter) |
#2650 |
Corporate Slave
during idle is umiinit compressor at low pressure line natin kaya umiinit na rin ang buga sa loob, when running kahit mainit eh may air flow movement at nag dissipate ang init kahit na sobrang init.
#2651 |
![]() Drives: Yaris Y 2007, Blue Join Date: Feb 2012
For info lang mga kayaris, na-try nyo na ba i-check yung chassis numbers/letters and compares it to your Istamara Card? it happened to me, in the last 2 digit, yung isang number na 6 sa chassis pero sa istimara card ko is 9, ang nakatuklas pa yung Inspector sa MVPI, then nag file ako ng amendment sa Muror, kaso 3-4 weeks release ng paper bago ka maka proceed for MVPI. Advice din na maaga magpa MVPI prior to your istimara renewal in case may ganitong problema hindi ka aabutan ng istamara expiration.
#2652 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: yaris Y 2010 A.K.A. "sky" Join Date: Jul 2010
Ciao !!! Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter) Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way |
#2653 |
![]() Drives: toyota yaris 2012 Join Date: Jun 2012
ganun din boss yung auto ko, AT din yun saken.. may na ugong nga na parang bubuyos.. kada pitik mo ng gas pedal may bubuyog nga.. bat kaya ganun?
#2654 |
Automatic ang transmission. Basta pag fast/quick rpm dun lumalabas ung amoy,pero nawawala din after two minutes or something,sabi ng toyota service center wala nman daw problema sa transmission o kya s engine.
#2655 |
ganun din yung yaris ko, naka AT din ako, nadinig ko yung saken nung minsan binaba ko ng damam.. kasama ko si pareng syntax. kahit sya nadinig nya. well i think its just normal. kaya lang kase pag malayuan biyahe medjo masakit sa tenga sa sobrang tining nung buzzzzzzzzzz.. okey lang sana kung jeeeeeeeeeppppppp ang tunog, kaso buzzzzzzzzzzzz eh.
#2656 | |
#2657 | |
#2658 |
#2659 |
![]() Drives: toyota xa 2004 model Join Date: Jul 2012
magandang umaga po! tanong ko lang po sana kung saan makakabili ng "window riser" yung mechanism na nagtataas at baba ng power window..,any suggestions po ng mga suking tindahan nyo?..hehehe maraming salamat po!
#2660 | |
Hope it Helps |
#2661 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan 2010 "shadow" Join Date: Mar 2010
question lang po, power windows na ba at naghahanap ka lang replacement? or manual pa rin at gusto mo gawin power windows?
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter) Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way |
#2662 |
@ sir ricepower.,thank you sa idea at sa contact person..,
@ sir syntax.,power windows na po siya sir.,sira lang yung "riser" daw sabi nung mekaniko na pinuntahan ko.,buo daw yun kung bibilhin...,zero knowledge ako pag dating sa mga piyesa na ganyan...,hehehe... salamat mga sirs! |
#2663 |
bongski
Drives: yaris homeboyz Join Date: Jul 2012
mga sir.ask ko lng sana kung panu aalisin ung ilaw ng airbag sa panel board kung magpapalit ako ng steering wheel? may nagsabi kc sakin na kailangan daw ipaprogram ulit. thanks.
#2664 | |
