Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 07-18-2012, 05:31 PM   #2647
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
saglit lang yan tol he he he
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 07-19-2012, 04:04 AM   #2648
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
Originally Posted by jonimac View Post
Palagay ko bro palitin na yung FUEL TANK CAP, as per http://www.toyota.com.sa/en/maint02.asp, check mo lang. Napansin ko rin yan lalo na ngayon sobrang init. ...parang may o may singaw na.
Originally Posted by charlieXX View Post
Tol duke at joni normal yun kasi yung ating gas tank eh hindi po sealed type, sadyang may pressure release valve yun kahit bagong paandar mo ng naka park na mainit yung kotse, pag andar amoy na amoy yung gas kasi mag release yun sa valve once na mag circulate na ang gas sa system ng kotse natin. Nothing to worry
salamat mga tol hindi pala ako nag iisa
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 07-19-2012, 06:03 AM   #2649
rickyml
rickyml's Avatar
Drives: Yaris 2008
tanong ko lang. bakit kapag naka-idle ako lalo na sa traffic light... parang mainit na ang ibinubuga ng AC. pero once na mag1st gear ako lumalamig na? di kaya dala lang ng panahon?
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 07-19-2012, 08:29 AM   #2650
charlieXX
Corporate Slave
charlieXX's Avatar
during idle is umiinit compressor at low pressure line natin kaya umiinit na rin ang buga sa loob, when running kahit mainit eh may air flow movement at nag dissipate ang init kahit na sobrang init.
Old 07-19-2012, 03:51 PM   #2651
gwafu187
Drives: Yaris Y 2007, Blue
For info lang mga kayaris, na-try nyo na ba i-check yung chassis numbers/letters and compares it to your Istamara Card? it happened to me, in the last 2 digit, yung isang number na 6 sa chassis pero sa istimara card ko is 9, ang nakatuklas pa yung Inspector sa MVPI, then nag file ako ng amendment sa Muror, kaso 3-4 weeks release ng paper bago ka maka proceed for MVPI. Advice din na maaga magpa MVPI prior to your istimara renewal in case may ganitong problema hindi ka aabutan ng istamara expiration.
gwafu187 is offline   Reply With Quote
Old 07-20-2012, 03:44 PM   #2652
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
Salamat pre sa magandang payo...
Ciao !!!
xtremist is offline   Reply With Quote
Old 07-20-2012, 04:15 PM   #2653
m.paule
m.paule's Avatar
Drives: toyota yaris 2012
ganun din boss yung auto ko, AT din yun saken.. may na ugong nga na parang bubuyos.. kada pitik mo ng gas pedal may bubuyog nga.. bat kaya ganun?
m.paule is offline   Reply With Quote
Old 07-21-2012, 11:02 AM   #2654
JonathanHB2011
Drives: Yaris 2011 1.3L
Hindi ba amoy clutch, baka naman naka babad ang clutch mo or baka mababa na ang pedal mo at may sabit ang clutch mo
Automatic ang transmission. Basta pag fast/quick rpm dun lumalabas ung amoy,pero nawawala din after two minutes or something,sabi ng toyota service center wala nman daw problema sa transmission o kya s engine.
JonathanHB2011 is offline   Reply With Quote
Old 07-21-2012, 02:51 PM   #2655
m.paule
m.paule's Avatar
ganun din yung yaris ko, naka AT din ako, nadinig ko yung saken nung minsan binaba ko ng damam.. kasama ko si pareng syntax. kahit sya nadinig nya. well i think its just normal. kaya lang kase pag malayuan biyahe medjo masakit sa tenga sa sobrang tining nung buzzzzzzzzzz.. okey lang sana kung jeeeeeeeeeppppppp ang tunog, kaso buzzzzzzzzzzzz eh.
Old 07-21-2012, 02:59 PM   #2656
m.paule
m.paule's Avatar
Originally Posted by xtremist View Post
mga kayaris, I started this thread para sa mga sari saring kuro kuro at katanungan na hindi related sa thread para maminimize natin na mag mixed up ang mga usapan. d2 nlng po ntin ipost...salamat.
1st question : napapansin ko na sa tuwing aabot ako ng 100 kph, may naririning akong "buzz" sound, prang langaw o bubuyog ang tunog nya, kpag lagpas n ko ng 120 at nwla ung alarm, wla ndin ung tunog, ano kaya yun?
para pala dito yung comment ko kanina. pati ako naguluhan.. waaaaaaaaah...
Old 07-22-2012, 09:03 AM   #2657
xtremist
xtremist's Avatar
ganyan ang akin, ngayon d ko na nadidinig dahil sa broom broom ko...wahahaha..mas malakas nga lang ang ingay....
Ciao !!!
Old 07-22-2012, 02:09 PM   #2658
m.paule
m.paule's Avatar
uu nga noh.. so far kase car stereo ang tinotodo ko... waaaaaaaaaaahh...
Old 07-31-2012, 05:47 PM   #2659
toyotaXa
Drives: toyota xa 2004 model
magandang umaga po! tanong ko lang po sana kung saan makakabili ng "window riser" yung mechanism na nagtataas at baba ng power window..,any suggestions po ng mga suking tindahan nyo?..hehehe maraming salamat po!
toyotaXa is offline   Reply With Quote
Old 08-01-2012, 05:51 AM   #2660
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Thumbs up
Medyo madugo sa bulsa yang part na yan lalo na kung buong mechanism. i suggest na pasyal ka sa Junk Yard sa may 2nd Industrial, Dammam. Or contact ATOH - 0598680357 - May junk shop na pinoy sa may junk yard area. Twagan mo na lang para sigurado at kung wala sa kanya, alam nya kung saan hanapin or ka-compatible na ibang car.
Hope it Helps
ricepower is offline   Reply With Quote
Old 08-01-2012, 09:32 AM   #2661
syntax
syntax's Avatar
question lang po, power windows na ba at naghahanap ka lang replacement? or manual pa rin at gusto mo gawin power windows?
Old 08-01-2012, 11:00 AM   #2662
toyotaXa
@ sir ricepower.,thank you sa idea at sa contact person..,
@ sir syntax.,power windows na po siya sir.,sira lang yung "riser" daw sabi nung mekaniko na pinuntahan ko.,buo daw yun kung bibilhin...,zero knowledge ako pag dating sa mga piyesa na ganyan...,hehehe... salamat mga sirs!
Old 08-06-2012, 02:01 AM   #2663
bongskitamtam
bongski
Drives: yaris homeboyz
mga sir.ask ko lng sana kung panu aalisin ung ilaw ng airbag sa panel board kung magpapalit ako ng steering wheel? may nagsabi kc sakin na kailangan daw ipaprogram ulit. thanks.
bongskitamtam is offline   Reply With Quote
Old 08-06-2012, 03:31 AM   #2664
xtremist
xtremist's Avatar
pre, akin din ganyan, payo lang, wag mo na alisin, buksan mo nalang yung panel tapos takpan mo yung LED light...hehehe, sa akin pinabayaan ko nalang...hindi naman nag iingay eh, naka ilaw lang
Ciao !!!
