#289 |
By the way, I can't win, if my guess is the closest, next best guess wins.
No one is going to say this thing might blow 15 extra horsepower? Woosies!!
#290 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
wouldn't there need to be a greater balance of intake to exhaust to be able to even possibly gain that much more, i.e. a large diameter mid-pipe to ensure higher out flow with the increased inflow.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#291 |
^ Of course, but we're just having fun guessing right? If you saw my guess, you'd know I was kidding.
#292 |
![]() ![]() ![]() Drives: 2010 Prius, 2007 Yaris Sedan Join Date: Oct 2009
zero change
#293 |
play every day
That may be the safest guess of all...
![]() Since torque numbers are also being included, and I guessed +2hp at peak, I think the torque will be -3 since the runners are shorter and larger in diameter. The manifold might have greater usefulness with forced induction rather than in a normally aspirated application. It can easily handle being pressurized. I saw the throttle body adaptor. They're machining a smooth transition between the smaller bore diameter of the throttle body and the larger diameter of the manifold inlet. |
#294 |
I think I'll go with +4hp and slightly reduced torque. I'd love for Golddeenoh's (or even mazilla's) guesses to be correct instead!
#295 |
^ tooter needs two numbers from ya, tk
#296 |
play every day
#297 |
I'll go with +4whp and -3% torque...
What can I say? I'm an optimist. Plus I'm shooting for a somewhat similar setup myself.
Last edited by tk-421; 07-21-2012 at 01:14 AM. Reason: **slams head repeatedly on wall** |
#298 | |
tk, I meant a whp and a torque number, both peak. That is the format for guessing.
#299 |
Fixed!
#300 | |
play every day
#301 |
I am soooo chompin' at the bit over this one.
I just want to see it on the car and on the dyno (along with numbers). the mock up you have with the intake and the flange looks good. |
#302 |
play every day
I've been test fitting the prototype flange to the engine...
![]() There are a couple of areas that need to be filed to fit because we went 3mm larger on the perimeter to accomodate the larger runners. There's one more spot to file near the middle of the fuel rail, so I should have it on today, and when the fitting is done I'll be sure to post some more pics. Wait till you see it with the runners on... it's gnarly.
#303 |
play every day
I just set on the runners to check the clearances... (goody
)![]() ![]() Looks really neato.
#304 |
Depot Damager
Drives: '08 Liftback Join Date: Jul 2012
You plan on wrapping them?
2008 Yaris Liftback - Bought in '12 with 80k Sold in '17 with 180k Bought back in '20 with 270k Currently collecting parts for the 2zr swap |
#305 |
play every day
Nope.
![]() There are a lot of really nice options for finishing the manifold, and I'll be choosing one of them. In my opinion, wrapping looks crappy, so obviously I'm more concerned with looks than performance.
#306 |
looks good
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
