Old 07-26-2012, 04:31 PM   #361
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by Golddeenoh View Post
looks like your "j" and "t" made a baby or you put the lower case "t" backwards :D
Yes, I did that on purpose to create "mirror image" symmetry between the two t's and o's. Something unusual and out of the ordinary is what makes a logo catchy.
Old 07-26-2012, 04:55 PM   #362
upper case J's are not fully crossed like T's are.
They are in serif fonts (Times/etc.).
The font for this forum is a sans serif font (verdana/helvetica/arial) where this is no crossing at all or "half crossed".
Helvetica J:
Times New Roman J:
Old 07-26-2012, 07:05 PM   #363
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Augh! He said serif!!
I agree about the catchy logo idea though, and can appreciate the effort to use simple shapes for easier manual G-code.
Old 07-26-2012, 07:32 PM   #364
tooter
play every day
tooter's Avatar
Yes. I just thought like the machine would think:
2 full circles oo
2 semi circles, each with a + at one end
1 3/4 circle with a horizontal _
1 semi circle with a vertical l
Old 07-26-2012, 07:49 PM   #365
tooter
play every day
tooter's Avatar
Picked up all the pieces from the CNC machine shop today...
Cranky... you can see the the areas on the inside of the outer runners that will be undercut with a hand file to the line scribed by the machine that matches the Yaris intake ports on the head. The solution was so simple.
Next up is an installation clearance test of everything including test fitting the throttle body...
...and then it's off to the welder.
Old 07-26-2012, 08:10 PM   #366
Viperoni
Drives: 2005 Toyota Echo
Lookin good :)
2006 Saturn Ion Redline
Old 07-26-2012, 08:28 PM   #367
slap that shit in the car!
Old 07-26-2012, 08:37 PM   #368
tooter
play every day
tooter's Avatar
One step at a time...
Old 07-26-2012, 10:53 PM   #369
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
What's sealing the adapter for the TB to the manifold?
Old 07-27-2012, 12:02 AM   #370
tooter
play every day
tooter's Avatar
A stock Corolla throttle body gasket seals the adaptor to the manifold...
It's a thin stiff metal sheet with rubberized coating on both sides. All of the gaskets used are OEM.
Those three black allen bolts holding the adaptor to the manifold are screwed into the original threaded Corolla throttle body mounting holes.
Old 07-27-2012, 03:43 AM   #371
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
I can't wait to see what this does on a dyno. So close!
4/20 NEVER FORGET is offline   Reply With Quote
Old 07-27-2012, 07:27 PM   #372
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Damn damn damn hurry up!!! ;)
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-27-2012, 07:45 PM   #373
Billiam
Drives: '10 White Yaris 4D LB
So is this thing going to be a "shower" or a "grower"?
If you want to enjoy your car, stay off of the internet.
Old 07-27-2012, 09:18 PM   #374
tooter
play every day
tooter's Avatar
Far more likely to be a "shower".
Remember that the Toyota engineers could model the plastic intake manifold in absolutely any shape, so I'm certain that what they came up with was the best for overall driveability.
Now that all the parts are back home, I just took a cloth measuring tape to the runners of both manifolds and am suprised to discover that the runners are just slightly longer than the stock Yaris runners!
Yaris runners, end to end: 19"
Tooter runners, end to end: 20"
Just by looking at both, Dang! I would have sworn that the Corolla's were a lot shorter! It was the larger diameter that only made them appear that way. This bodes well for low end performance, although I still believe that low end torque will suffer somewhat because larger diameter runners means slower air velocity at low rpms. Now how much low end loss is an open question which will be settled on the dyno.
Here's a pic of the inside of the stock manifold...
You can see the entrance to the first runner at the bottom which is at 90 degrees to the manifold's intake, and the plenum is quite large.
In contrast, these runners are all pointing directly at the manifold's intake and are all the same short distance from it...
I believe that this manifold would really shine under a forced induction situation. First, because it it is plenty strong to take being pressurized, and second, it can handle 20% more air flow under equal conditions because it was made for an engine with 20% more displacement.
Old 07-27-2012, 11:09 PM   #375
Bluevitz-rs
Did you think of maybe running a Corolla TB on it later on down the road?
Old 07-28-2012, 12:38 AM   #376
tooter
play every day
tooter's Avatar
I don't think so, because I don't want to deal with trying to rig up throttle linkage and fighting ECU issues. It's much simpler just to run the stock Yaris throttle body.
Old 07-28-2012, 05:52 AM   #377
4/20 NEVER FORGET
I thought I read a thread where people were using a corolla TB with no wiring/ecu issues. Plug and play. Why not go that route? My plan is to buy another stock intake manifold and port match it to a corolla TB.
Old 07-28-2012, 11:25 AM   #378
tooter
play every day
tooter's Avatar
Can you find where you saw that? Is the Corolla throttle body also drive by wire?
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
