#541 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
what is the model of your fuel regulator ? did it came with fittings male-male or you had to buy some ?
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#542 |
AEM Part Number 25-302BK they do not come with fittings. im sure Garm will have them in stock.
05 Scion tC allmotor 350+ hp 9.34@144mph 05 Scion tC sfwd 880hp 9.96@147mph 05 Scion xB 280hp 12.97@104mph 07 Toyota Yaris 357hp 12.80@107mph |
#543 |
^ Thanks, we do, and the gauges too.
#544 |
Good i will call uou or jeff next week!:)
Do you have them in red the regulator ?
#545 |
I'll check, I know I have black for sure.
#546 |
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
I am using a Aeromotive regulator and it did not come with any fittings. The stock rail spacers look like they will work good. I am using Scion TC/Camry injectors from a 2AZ-FE engine. For now. Will upgrade to some 550cc denso injectors later.
#547 |
C'est la vie
More progress.
#548 |
Cooll man thanks for pictures! Inlike the way you place the regulator! Might copy it :$
Post pics if where you run the hose to the tank :)
#549 |
C'est la vie
daily updates
#550 |
way to go!
#551 |
what dose it look like when you compress it all the way down. make sure it dosent kink.
#552 |
post pics of when its compressed :)
where did you ran the 6an new feed line.. ? where can i reach the pump assembly ? under passenger seat ?
#553 |
C'est la vie
The pump is under the rear seat under a silver piece of sheet metal. I did shorten the line to the pump a little. That pic was not the final assembly. The line will run under the car and tied to the factory line that I am going to use as the return. I will post some more pics tomorrow if it doesn't rain.
#554 |
Good thanks!!!:-)
Fun to follow thread like this :-) will make thing easier when i will install mine /)
#555 |
wow man....i rmeoved the rear seats(and did not pu them back :D) its BIG this fuel pump assembly!!! i tought I would have some thing that fits in my hand...ITS BIGGG!! ahah...just wanted to share..
#556 |
^ dunno what you mean. The pump is very small
#557 |
I meant..nott the pump itself...the cylinder in which it stands...its pretty compare to what i had expected lol
#558 |
C'est la vie
The fuel system is done and WOW what a difference. I now know the stock regulator was seriously choking off fuel and could not flow enough to handle a turbo yaris above 5 psi. The only reason it was working was because of the larger injectors and the fact that I was increasing the duty cycle to max them out. I went from plus 80% fuel at the high rpm end of my map to -12% at the same spot on my map with the new fuel system. My new regulator adds 1 psi of fuel pressure for every 1 psi of boost. This does most of the tuning for you. You absolutly still need a piggy back though. I took more pics of the system and some pics when I was doing some "HOT LAPS"
and tuning.Also as far as parts used: fuel rail, scion TC injectors, Aeromotive fuel pressure regulator, 1/8 npt fuelpressure guage on regulator, 1 -6an bulk head fitting with nut, 6 straight -6 hose end fittings, one 90 degree -6an hose fitting, 1 -8an straight cut to -6an hose fitting with o-ring, one -8an straight cut to -6an with a 90 deg. bend and o-ring, 25ft of -6an black braided fuel line. I bought the line and almost all the fittings from e-bay and the last fitting from summit racing. That one was hard to find. Last edited by pimp my yaris; 08-12-2012 at 11:31 PM. |
| Under $2500 Turbo Kit w/Intercooler coming soon! | cdydjded | Forced Induction Forum | 58 | 09-23-2007 02:02 PM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 15 | 06-09-2007 01:24 AM |
| ZPI soon to release their turbo kit | turboyaris | Forced Induction Forum | 10 | 04-26-2007 02:52 PM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 30 | 04-04-2007 02:10 PM |
