Old 08-08-2012, 11:29 PM   #1
detroiter
detroiter's Avatar
195/60-15?
Needing to replace my tires and the stock size for the Yaris is rediculously expsenive. The 195 size is wayyyy cheaper in price but I don't know if it would be a good replacement size or not. I'm running Tokicos and Tein stech springs.
Any suggestions on what would be a good replacement for stock rim size and my suspension setup?
Old 08-08-2012, 11:37 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
I believe 195/60/15's actually fit much better than OEM 185's on stock suspension.
Old 08-09-2012, 12:26 AM   #3
detroiter
detroiter's Avatar
How about for my lowered setup? Is it still ok to run them?
Old 08-09-2012, 03:00 AM   #4
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I like the wide selection of long lasting high mileage 195/60 15 tires, and also like that they are almost exactly the same diameter as the stock 175/65 15's they replaced so that the speedometer and odometer stay accurate for valid gas mileage readings.
Old 08-11-2012, 02:45 PM   #5
detroiter
detroiter's Avatar
Thanks for the replies so far, I'm still trying to figure out if a 195/60/15 will be ok on a lowered setup though?
Old 08-11-2012, 02:55 PM   #6
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
If you are not changing wheels measure about 10 mm out from the sidewall and see if that point still clears you fenders.
Old 08-11-2012, 05:08 PM   #7
ciscobear
Drives: Toyota Belta
What are the prices like on a 195x55x15. I suspect 60 may rub with Teins.
ciscobear is offline   Reply With Quote
Old 08-11-2012, 06:26 PM   #8
1.5
Form>Function
1.5's Avatar
I ran 185/60/15s slammed on megan coilovers with no rubbing.
Old 08-11-2012, 06:46 PM   #9
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
It all depends on what you are truly asking, but you should be fine. I have just taken a bunch of photos for you with my stock 15" steelies and my Winterforce 195/60s. I am running 2" drop front and 2.25" on the rears with my AMRs. I just drove over to an autocross event and there was a couple places where I kid you not they had torn out 2-3' sections of the road for repair of something and the patch area where they had worked was about 3-5" deep! I didn't rub. I can't really give you a full turn radius opinion because my 18s totally shredded my plastic panels, but when I did have them in place I never recalled rubbing on full radius turns nor on the roadways with even serious dips/pothole hazards.
Remember too that winter tires tend to protrude more a the edges, etc than summer or all seasons. I hope that this helps at least a little even though I am running different springs.
Old 08-12-2012, 12:31 AM   #10
nookandcrannycar
Do you have the 195s on your car and if so are you getting better MPG than with the OEM 185 size? (I need to replace my tires in the near future)
Old 08-14-2012, 01:26 PM   #11
nookandcrannycar
That black 'band aid' on the dent is too funny!
Old 08-15-2012, 02:59 PM   #12
yaris_ninja
Yaris_Ninja
Drives: 2009 Yaris 5Door Hatchback
Send a message via MSN to yaris_ninja
You should have no rubbing issues. i have Tein S lowering springs that dropped my yaris 2inches all around. when i did drop my yaris i had the 18in TRD rims and they had 215/35-18 tires on them. they were rubbing alot but thats cause the overall diamater is about 3/4inch bigger. they mainly rubbed on the fender liner. i took them off and put the stock steelies and tires on and no rubbing at all. i would drive my yaris hard and it would bottom out at all. the only thing i had to be careful of was speed bumps lol. I currently have the 18inch wheels back on after i had new tires installed. I had to cut most of the liner put and rolled the front fenders myself. they still rub on the remaining liner so i am going to end up removing the liner completely. so yeah dont worry.
yaris_ninja is offline   Reply With Quote
Old 08-15-2012, 05:01 PM   #13
fnkngrv
fnkngrv's Avatar
It is the JDM thing to do, plus it protects where there is bare metal at least a little. I still can't figure out how the hit n run managed the weird type of damage that occurred. My door doesn't have a dent for damage yet the doorjam on the body does...it is like the thin sheet metal of the door must have flexed.
Old 08-04-2015, 07:54 PM   #14
fullmonte60
intern
fullmonte60's Avatar
Drives: 2007 yaris 4 dr sedan
I felt much better about 195's after seeing your pics. off the car they look huge. the wheel cover makes the 185's look smaller....lol. pics soon
2007 nautical blue sedan, 5 spd, TRD PTR11-52071, TRD PTR03-52080, K&N drop-in.
fullmonte60 is offline   Reply With Quote
Old 08-05-2015, 07:56 AM   #15
IllusionX
Drives: 07 Yaris Sedan Aero
I never liked the 195/60's on the yaris. The car sits 1/2" higher.
Sent from my A0001 using Tapatalk
Old 08-05-2015, 09:39 PM   #16
Supra_Yaris
Logan
Drives: 2009 Yaris Liftback Base MT
You should be fine. I am on Tanabe DF210s which is about a two inch drop. I have been currently running 195-60-15 tires. There has been no rubbing for as long as I have had them (5 months.) Good luck in your tire search.
Supra_Yaris is offline   Reply With Quote
Old 08-05-2015, 09:54 PM   #17
Rigaud
Drives: 2009 Yaris
I'm sure he's fine, it's been three years this thread was posted in! lol
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 08-08-2015, 10:12 PM   #18
fullmonte60
intern
let's hope so! i'm very happy with the 195/60/15's and TRD rear sway.
