Old 08-14-2012, 11:48 PM   #595
Autocross72
Drives: 2009 3rd Polar white
Subscribe
Autocross72 is offline   Reply With Quote
Old 08-15-2012, 12:15 AM   #596
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
Where's the beef
4/20 NEVER FORGET is offline   Reply With Quote
Old 08-15-2012, 12:26 AM   #597
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Still waiting on the 90 degree silicone coupling to arrive so that I can finish off the air filter. Sorry, no air filter... no dyno. I'm not going to wreck my engine.
I want to see the results just as much as any of you do.
Old 08-15-2012, 12:29 AM   #598
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
^ we're still waiting, bro. anxiously waiting!
Old 08-15-2012, 12:39 AM   #599
Autocross72
One or two pulls on a Dyno withouut an air filter isn't going to hurt your engine. That said, I'd be more interested in seeing the Dyno numbers with the filter because that is how it will be run in the real world and can be compared more directly to your previous Dyno pulls.
Old 08-15-2012, 01:17 AM   #600
tooter
play every day
tooter's Avatar
I agree.
The second set of dyno pulls need to be done under exactly the same conditions as the baseline pulls with the velocity stack and its matching air filter... except for the tooter manifold being the only change. I want to do this the right way.
Old 08-15-2012, 02:04 AM   #601
That's not going to happen unless ambient temperature and humidity are the same, along with other factors. Did you record ambient conditions and engine intake air temps when you did your baseline pulls?
I think everyone should consider that there is a notable margin for error, counted twice -- once for each dyno session.
Old 08-15-2012, 08:03 AM   #602
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
^ That's why I suggested he swap manifolds on the dyno, but he doesn't want to do that.
Old 08-15-2012, 10:43 AM   #603
It's tooter's show, I'm just enjoying the whole thing. And he's quite content if it doesn't make or lose great power. He's having great fun doing this -- that's all that matters.
I like clarity for all when I see words like "exactly the same"; that was the only purpose for my post. And... it makes the pool more interesting.
Old 08-15-2012, 11:28 AM   #604
tooter
play every day
tooter's Avatar
Yes. They were automatically logged on the chart:
78.46 °F
29.19 in-Hg
Humidity: 45 %
Since it's been really hot and dry, I'll try to pick an early morning dyno time on a day when the Santa Ana winds aren't blowing.
Old 08-15-2012, 11:35 AM   #605
tooter
play every day
tooter's Avatar
It's good you pointed that out, Garm.
By "exactly the same conditions", I meant engine conditions. That the only change between the first dyno runs and the second is the manifold and nothing else.
I'm already happy that the engine runs great, gets good mileage and that the manifold looks really cool. The change won't be much either way because the throttle body, ECU, and engine are all still exactly the same.
Old 08-15-2012, 12:15 PM   #606
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
you know...if you ordered your silicone coupler from us...you wouldnt be having this issue ;)
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-15-2012, 12:19 PM   #607
^ Or if he picked one up from my shop.
Old 08-15-2012, 05:21 PM   #608
tooter
play every day
tooter's Avatar
I had ordered one from an ebay seller and was sent a 45 degree instead of a 90 so he's making it right.
Old 08-15-2012, 06:57 PM   #609
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Or if he got one from ....oh wait, I don't sell anything.
-Type 07 FFL-
My odometer 03/11
Old 08-15-2012, 07:26 PM   #610
^ and on this forum, neither does malibuguy, and neither does tooter -- but the link to become a vendor is posted for anyone who wants to join the club.
Old 08-16-2012, 08:41 PM   #611
tooter
play every day
tooter's Avatar
I planned on making my own CAI like the one i made for my old xB. However, if these work out obviously im down for the flanges (as ive been sitting on a 1zz intake for quite a while) and ill just make induction custom to the manifold...and maybe perhaps given tooter graces, reproducing them for a few peoples who dont have fab skills?
Thanks for the offer, guy...
But I'll be producing complete bolt on tooters myself so as to be able to recover the initial design and production tool-up costs.
Think of your exhausts... When you design a system that no one else has, you want to be the one to make and sell them yourself.
Old 08-16-2012, 09:09 PM   #612
Cars with ITB's and velocity stacks dyno every day. Dyno shops don't have particulate matter floating around; if they did, I'd probably choose another shop.
Since that's not going to hurt your engine, it's not a valid reason to wait.
I don't care when you do it, just pointing out a bad argument when I see one.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
