Old 08-18-2012, 04:21 PM   #649
glad to help out -- FYI everyone, I'll be putting various hoses and couplings up on the site shortly.
Old 08-18-2012, 04:59 PM   #650
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Man, you're a life saver!
Here's the results...
It's ready to DYNO!
Old 08-18-2012, 05:00 PM   #651
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
DYNO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 08-18-2012, 06:08 PM   #652
tooter
play every day
tooter's Avatar
Just got back from test running the final air filter setup and the car runs great!
I was concerned that the MAF signalling might be impaired from cutting and trimming everything on the intake so dang short, but no CEL was triggered so it's good. There is absolutely no wiggle room for that giant air filter, and I'm sure glad that those silicone couplings are flexible because it wouldn't be there if they weren't.
Old 08-18-2012, 06:19 PM   #653
tooter
play every day
tooter's Avatar
Just called Harry at HK Motorsports Dyno Shop in Van Nuys...
...and we're all set for dyno runs this coming Thursday morning the 23rd.
Old 08-18-2012, 09:44 PM   #654
Yay
Old 08-18-2012, 10:32 PM   #655
fase4
Drives: Yaris TS 05
excellent!
fase4 is offline   Reply With Quote
Old 08-19-2012, 01:22 AM   #656
Viperoni
Drives: 2005 Toyota Echo
Time Machine - fast forward till Thursday morning :D
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 08-19-2012, 01:31 AM   #657
tooter
play every day
tooter's Avatar
We'll be there before you know it...
I picked Thursday because it will be the coolest day of the coming week with morning clouds and a high of 87.
The peak temprature doesn't hit until about 2 to 3 in the afternoon. I'm the first run scheduled at 11:00 in the morning when it should still be slightly overcast with temps in the high 70's...
...which is similar to the conditions of the baseline dyno runs which were 78 degrees and 45% humidity.
Old 08-19-2012, 01:26 PM   #658
ryanww
Drives: Yaris 1.5L 5 doors
Originally Posted by tooter View Post
Very clean engine bay...Nice!
ryanww is offline   Reply With Quote
Old 08-19-2012, 01:43 PM   #659
tooter
play every day
tooter's Avatar
Thanks... It's a little more messy right now until I get some permanent locations for the hoses all worked out...
Old 08-19-2012, 04:55 PM   #660
tooter
play every day
tooter's Avatar
Fabricated a simple permanent mount for the radiator vent cap assembly and rerouted some of the hoses to better locations...
...so the area around the throttle body looks a little less cluttered.
4 days to dyno.
Old 08-20-2012, 08:27 AM   #661
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
Dude, that looks gorgeous! Great work, this has been one of the most informative/entertaining threads on this board in a while!
Old 08-20-2012, 10:14 AM   #662
anomoly40
Depot Damager
Drives: '08 Liftback
2008 Yaris Liftback -
Bought in '12 with 80k
Sold in '17 with 180k
Bought back in '20 with 270k
Currently collecting parts for the 2zr swap
anomoly40 is offline   Reply With Quote
Old 08-20-2012, 06:58 PM   #663
Jeff@MicroImage
"Know it all"
Jeff@MicroImage's Avatar
Drives: Lancia Delta Integrale
Tooter, I would recommend buying or borrowing a Scanguage before the dyno so you can monitor peak MAF readings as well as fuel trims (both long term and short term).
www.microimageonline.com
Jeff@MicroImage is offline   Reply With Quote
Old 08-20-2012, 07:15 PM   #664
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
^ that's probably the best way to determine flow with either manifold on.
Old 08-20-2012, 07:42 PM   #665
tooter
play every day
tooter's Avatar
Hey Jeff,
What's a peak MAF reading, and why do I need it? And what are long term and short term fuel trims, and why do I need them?
Remember, you're talking to a dummy here.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
