#649 |
glad to help out -- FYI everyone, I'll be putting various hoses and couplings up on the site shortly.
#650 |
play every day
Man, you're a life saver!
![]() Here's the results... ![]() ![]() ![]() ![]() ![]() It's ready to DYNO!
#651 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
DYNO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#652 |
play every day
Just got back from test running the final air filter setup and the car runs great!
![]() I was concerned that the MAF signalling might be impaired from cutting and trimming everything on the intake so dang short, but no CEL was triggered so it's good. There is absolutely no wiggle room for that giant air filter, and I'm sure glad that those silicone couplings are flexible because it wouldn't be there if they weren't.
#653 |
play every day
Just called Harry at HK Motorsports Dyno Shop in Van Nuys...
...and we're all set for dyno runs this coming Thursday morning the 23rd. |
#654 |
Yay
#655 |
![]() Drives: Yaris TS 05 Join Date: Jun 2011
excellent!
#656 |
Time Machine - fast forward till Thursday morning :D
#657 |
play every day
We'll be there before you know it...
I picked Thursday because it will be the coolest day of the coming week with morning clouds and a high of 87. The peak temprature doesn't hit until about 2 to 3 in the afternoon. I'm the first run scheduled at 11:00 in the morning when it should still be slightly overcast with temps in the high 70's... ...which is similar to the conditions of the baseline dyno runs which were 78 degrees and 45% humidity.
#658 |
![]() Drives: Yaris 1.5L 5 doors Join Date: Aug 2012
#659 |
play every day
#660 |
play every day
Fabricated a simple permanent mount for the radiator vent cap assembly and rerouted some of the hoses to better locations...
![]() ...so the area around the throttle body looks a little less cluttered. 4 days to dyno.
#661 |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
Dude, that looks gorgeous! Great work, this has been one of the most informative/entertaining threads on this board in a while!
#662 |
Depot Damager
Drives: '08 Liftback Join Date: Jul 2012
2008 Yaris Liftback - Bought in '12 with 80k Sold in '17 with 180k Bought back in '20 with 270k Currently collecting parts for the 2zr swap |
#663 |
"Know it all"
Drives: Lancia Delta Integrale Join Date: Jan 2012
Tooter, I would recommend buying or borrowing a Scanguage before the dyno so you can monitor peak MAF readings as well as fuel trims (both long term and short term).
www.microimageonline.com |
#664 |
^ that's probably the best way to determine flow with either manifold on.
#665 | |
play every day
![]() What's a peak MAF reading, and why do I need it? And what are long term and short term fuel trims, and why do I need them? ![]() Remember, you're talking to a dummy here.
#666 |
"Know it all"
http://auto.howstuffworks.com/fuel-e...-computer1.htm
http://www.physicsforums.com/showthread.php?t=409704 http://www.audizine.com/forum/showth...F-or-turbulent
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
