Old 08-23-2012, 05:39 PM   #721
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
not so bad man!!!I want that HP hahaha
Interior:ALL red, black roof
Old 08-23-2012, 05:55 PM   #722
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
I wouldn't call the manifold a failure till we see the dyno, just because the power output is low on a stock engine doesn't mean it won't work wonders on a non stock application.
Old 08-23-2012, 06:09 PM   #723
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
I'm with xnamerxx, Turbo set up will benefit the most, especially for systems that are going beyond the 20 or so psi (I think that is the number i remember reading) that the plastic box limits it's self to. either way still a cool product.
can we get a re post of the guesses to see how close everyone was. I don't even remember what i had put.
Old 08-23-2012, 06:21 PM   #724
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
Good job on seeing that project through. It was a lot of fun to watch.
Next you should swap the TB to a Corolla throttle body :)
4/20 NEVER FORGET is offline   Reply With Quote
Old 08-23-2012, 07:28 PM   #725
packetrace
packetrace's Avatar
would you mine doing an other dyno run..without the 90 degree....and so just the velocity stack....it wont hurt the car for just a dyno run :P or maybe but a net around it
Old 08-23-2012, 07:32 PM   #726
He probably would...if you paid for it
Old 08-23-2012, 07:34 PM   #727
packetrace
packetrace's Avatar
lol no
thats why I asked would you mind to....
Old 08-23-2012, 08:15 PM   #728
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
I still applaud you for getting it out of your head and onto the car
Old 08-23-2012, 08:40 PM   #729
justjesus
justjesus's Avatar
Drives: 2008 Liftback
^ I'm calling your boss.
is THAT why i got a stack of work to do now?!?!?!
Tooter: thanks for trying this out man.
Garm: prototype? huh? I don't want to thread jack, so can you link me any links. Just not sausage links!!!!
Old 08-23-2012, 09:04 PM   #730
Viperoni
Drives: 2005 Toyota Echo
Good effort, too bad it didn't make more power. A mad props for going beginning to end on it :)
2006 Saturn Ion Redline
Old 08-23-2012, 09:07 PM   #731
anomoly40
Depot Damager
Drives: '08 Liftback
So I win? I got hp right and was off 2 torques.
2008 Yaris Liftback -
Bought in '12 with 80k
Sold in '17 with 180k
Bought back in '20 with 270k
Currently collecting parts for the 2zr swap
anomoly40 is offline   Reply With Quote
Old 08-23-2012, 09:29 PM   #732
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Here's a comparative chart of the best of the basline runs and the best of the tooter runs...
Old 08-23-2012, 09:46 PM   #733
tooter
play every day
tooter's Avatar
Originally Posted by Jason@SportsCar View Post
What, only +1hp/-1tq... What about all of the glowing reviews from your butt dyno.
It's ok... I can handle a little ridicule, Jason.
Remember that the dyno runs are at wide open throttle and I don't normally drive at wide open throttle. I just drive like a regular transportation driver. And at under partial throttle conditions and low rpms the tooter manifold does perform great. In fact that was one of the things I was most concerned about, whether it would be driveable under normal everyday conditions.
I still need a few more fillups with the tooter to get an accurate comparison to the baseline gas mileage average.
Old 08-23-2012, 10:04 PM   #734
Jason@SportsCar
I still need a few more fillups with the tooter to get an accurate comparison to the baseline gas mileage average. :smile
Either your butt dyno is way out of wack, or I am looking at the wrong trace on the dyno, everything I see indicates a loss of power under 5300rpm. The way I see it low end power, and thus driveability has gotten worse. But it looks pretty.
Old 08-23-2012, 10:13 PM   #735
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Damn bittersweet ending...thanks for putting the effort out there to find out.
I wonder if could aggressive tuning n/a could make gains along with a larger tb?
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-23-2012, 10:14 PM   #736
malibuguy
Obsessed with 1.5L
Actually...some of that low end loss could be due to the supershort intake
I wonder a long intake into the fender well could make magic happen? I know you have flooding issues so thats a no go for you
-96 Tercel 4dr
Old 08-23-2012, 10:19 PM   #737
tooter
play every day
tooter's Avatar
Well, that's why I did comparative dyno runs, because they accurately show the difference. Under the partial throttle conditions of normal driving the difference isn't noticeable. If your gas pedal is to the floorboard all the time you're driving then you could notice the difference.
Old 08-23-2012, 10:31 PM   #738
tooter
play every day
tooter's Avatar
I've been thinking about that too, malibu...
That intake is as physically short as possible to fit the filter. I might try a longer cold air intake just to see what happens. I can always take it off during the wet season. I'm not done experimenting yet.
Harry, at the HK Motorsports Dyno Shop in Van Nuys said that he'd open his place on a Sunday for a $70 Dyno Day if there are at least 5 cars to run. I'm going to post this in the California section just to see if anyone is interested.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
