Power Windows Question
Hello All,
didnt know exactly where to post this. As those with power windows know, the driver's window comes with the "auto" down option when you push the switch all the way down. My question is, can this capability be expanded to the other windows? |
![]() Drives: 2007 toyota yaris sports Join Date: Oct 2010
you would have to switch out the switches with the one like the driver door. the driver door is a double switch. the other ones are single switchs
Thanks, do you know if this would be something easy? Is there alot of wiring involved with swapping switches?
The easiest way to do it is to use one (2 dr) or two (4 dr) DEI 530T modules. Here is a thread with a DIY that I put together for wiring them:
http://www.yarisworld.com/forums/showthread.php?t=31473
Thanks CT!
| Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 09:34 PM |
| Power Windows Leg Room | nwdixieboy | General Yaris / Vitz Discussion | 9 | 04-06-2006 07:19 AM |
