![]() Drives: HB Toyota Yaris 07 VVT-i Join Date: Oct 2010
On friday my yaris was having a slow start up
So i took it to get checked at autozone The guy said "your battery voltage is to low so I can't run my test." So i went to pepboys To get my battery checked n they replaced it since it Had low voltage n didn't pass the battery test. As soon as i put in the new battery, thats when The rough idleing started. Since i had some blue Corrosion on my postive terminal i bought some Cleaner to clean any other build up on my terminal. I got home after two stalls! I took off my alternator to Get checked and it passed 3 times. So i bought a New belt since my old one was bad. When i tighted myy belt I hit my ocv connector. After a new belt n alternator check My car still had rough idle. So i thought it could be my spark plugs So i bought new ones n still nothing. So i ran a cel scan on my car Since i cleaned my terminals after i put new spark plugs n got A check engine light. The codes i got were P0010 n another one for the MAF. (Mind this: when i took my alternator off i forgot to Disconnect the postive terminal, so as soon as i show A spark when i pulled that grey cover connector n touched it With the socket wrench. I stopped n disconnected my + terminal) I cleaned my maf with maf cleaner n still nothing. So Yesterday i bought a new ocv since my lastone was broken On the plastic area from tightening my alternator. I put The new ocv in and still very very rough idle. Any advice or help please. |
After a battery disconnect, the ECU goes into a learn state. Until it is finished 'learning' idle can be very low. When I am in that state, my idle can drop to as low as 350 rpm. Engine barely stays alive that low. After a good 30 minutes or so of driving, idle is back to where it should be.
WeeYari thank you.
I'll give that a try |
| Tags |
| rough idle |
| DIY - 1.8L 1ZZ-FE TB Connector Chip Swap | Yaris T-Sport | DIY / Maintenance / Service | 332 | 04-03-2022 01:39 AM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| Increase alternator output or adjust idle? | mazilla | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 05-28-2011 12:49 AM |
| Cold Idle Speed Question... | cpnnz | DIY / Maintenance / Service | 9 | 11-04-2009 05:31 PM |
| Help with low idle from Venezuela | Yarisvene | DIY / Maintenance / Service | 5 | 06-23-2007 08:23 AM |
