Old 12-23-2011, 08:59 PM   #397
spectra
spectra's Avatar
Drives: 2007 Yaris
Yup! even had time to clean the car top to bottom
spectra is offline   Reply With Quote
Old 12-31-2011, 10:04 PM   #398
the beagle
Drives: '08 Liftback
Cruise for Christmas!
After reading the entire thread on DIY cruise, I installed a $9.73 cruise on my son's 08 liftback, thanks to all of you for your perseverance and innovation. We ran the wires to the console between the seats. The two button controls are partially covered by the brake handle. A very clean install if I do say so myself.
CTScott, how can I get one of those ECM terminal pins?
the beagle is offline   Reply With Quote
Old 01-01-2012, 03:52 PM   #399
PMed with payment info. I have the pins available.
Old 01-07-2012, 12:15 PM   #400
bad
Winterizing
bad's Avatar
Drives: 2010 Toyota Yaris Hatchback
I've used the CTScott cruise control system and procedure. works great. I have little experience working on cars. successful install.
33.7 mpg in PA
bad is offline   Reply With Quote
Old 01-07-2012, 12:20 PM   #401
bad
Winterizing
bad's Avatar
oh but i should mention you'll need a variety of butt splices and extra wire ... i wish i could remember the gauges but its all around 16 to 22. depening on what wire you use to ground you might need a different gauge lug for that too.
33.7 mpg in PA
Old 06-13-2012, 07:59 AM   #402
menz
Drives: yairs blue 2007 automatic 1.3
I am from Egypt (middle east). I have seen this DIY years ago but never had the guts to do it. I am a noob when it comes to car mechanics and also afraid of electronics :D. I don't know if my car has cruise function. To summarize, I need to check if PIN 40 has 12 volts when ignition on. Wish me luck everybody. I hope that the car has the function so I can do it, my 300 kms daily route to work would be so much better. I think that toyota must have installed it in all the cars not specific to a certain segment. When I first bought the car it had no rear speakers and when I bought the speakers and during installation, I found out that all the wiring is done and all I have to do it place the speakers and that was it. Do I need to remove the steering wheel to get to the D3 connector??? :d
menz is offline   Reply With Quote
Old 06-13-2012, 08:27 AM   #403
Unfortunately your Yaris does not support the OEM cruise control. For 06-11 Yaris, only US/Canada ones with the 1.5L engine have it built into the ECM.
Old 06-13-2012, 02:13 PM   #404
menz
I really wished I have it. So just for my own curiouisity which one is the D3 connector where is it exactly
Old 06-13-2012, 03:09 PM   #405
It is on the bottom of the steering column. My complete DIY shows how to get to it:
http://www.yarisworld.com/forums/showthread.php?t=33750
Old 09-01-2012, 12:40 PM   #406
yaryarbing
Budget Buster
yaryarbing's Avatar
Drives: 2007 Polar White Sedan
It Works!
Just installed the two switch DIY cruise control on my '07 Yaris Sedan. Can't believe it works! Not that I had any doubts in the DIY instructions. I have zero experience in electronics. I just bought the parts (<$10!), installed as instructed, and I now have cruise control!
Thanks so much for this thread and instructions. I am a traveling salesman with a four state territory. The cruise will make my travels SO much easier
-Yaryarbing
yaryarbing is offline   Reply With Quote
Old 09-02-2012, 12:37 AM   #407
chanka
Drives: Toyota allex
Cruise Cotrol
Hi Scott,
If I don't have cruise control in my 08 yaris (M5) (New Zealand New) hatch how can I fit CC ?
Cheers.
Chanka
chanka is offline   Reply With Quote
Old 09-02-2012, 06:56 AM   #408
Originally Posted by chanka View Post
Hi Scott,
Cheers.
Chanka
For your car you would need a complete aftermarket system, since your ECM does not have the functionality built in.
Old 03-11-2013, 08:42 AM   #409
fascar228
Drives: vitz RS 1.5L 2006
Hi All,
I have a 2007 Vitz JDM 1.0L can the Cruise control mod work for my vehicle....
fascar228 is offline   Reply With Quote
Old 03-11-2013, 08:58 AM   #410
mf4361
Drives: Yaris Sedan
Since this thread is revived, I have to say, It worked on my 2007 Sedan (Canada)!! Started out with no tool, I spend ~$15 on it. Compare to, let say, OEM Cruise from dealership its almost nothing. Thanks CTScott for the awesome DIY writeup and everyone's help.
Now I need to work on making aesthetically look good.
mf4361 is offline   Reply With Quote
Old 03-27-2013, 09:31 PM   #411
johntam
j&t
Drives: 2007 4 door hatch back
Thanks guys for the detailed instructions for the cruise control installation for my '07 \yaris. It works awesome. J&T
johntam is offline   Reply With Quote
Old 06-21-2013, 03:33 AM   #412
bonox
Drives: Bronze 07
Hi All
I tried this today on my December 2006 YR. Is there a way to tell if you've made a connection to pin40 on A21? Is there a test resistance to ground or another pin for example?
Mine also does not have the blue wire populated in the fuse box for the clutch switch either. Does this mean it's a no go? There is a pin at the bottom (just not a wire coming out of the plug), which I tried grounding, but couldn't get CC to work.
Thoughts any of you gurus? :)
bonox is offline   Reply With Quote
Old 06-21-2013, 06:10 AM   #413
Originally Posted by bonox View Post
Hi All
For the pin 40 test, measure the voltage on the wire with the ignition switch in the on position. You should see 12 V on that pin.
The missing blue clutch switch wire is potentially a bad sign. Did you verify that there was not a connector taped to the harness, just above the clutch pedal?
Old 06-21-2013, 07:56 PM   #414
bonox
Drives: Bronze 07
Thanks Scott
Will check pin potential - didn't look for connector at the time, but I don't have one.
Cheers
b
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
