Old 06-21-2013, 03:33 AM   #21
bonox
Drives: Bronze 07
Hi All
I tried this today on my December 2006 YR. Is there a way to tell if you've made a connection to pin40 on A21? Is there a test resistance to ground or another pin for example?
Mine also does not have the blue wire populated in the fuse box for the clutch switch either. Does this mean it's a no go? There is a pin at the bottom (just not a wire coming out of the plug), which I tried grounding, but couldn't get CC to work.
Thoughts any of you gurus? :)
bonox is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
