#397 | |
The missing blue clutch switch wire is potentially a bad sign. Did you verify that there was not a connector taped to the harness, just above the clutch pedal?
#398 | |
![]() Drives: Bronze 07 Join Date: Mar 2012
Will check pin potential - didn't look for connector at the time, but I don't have one. Cheers b |
#399 |
![]() ![]() Drives: Want a yaris Join Date: May 2012
Is the clutch switch required? Is it's purpose to disengage the cruise when the clutch is pressed in?
#400 |
The clutch switch is required for MT cars. The switch works the opposite of the clutch start switch, which is why it is a separate switch. It does disable CC when the clutch is touched, to prevent revving.
#401 |
Thanks for the quick reply. My dad wants cruise in his 07 MT LB yaris. I'll get the part ordered.
#402 |
I stock all of the cruise control parts at less than dealer or mail order prices, if you need anything.
#403 |
![]() Drives: Yaris 2009 1.3 sol 100HP Join Date: Feb 2015
Hi Scott,
I have the 2009 yaris Sol 100HP MMT transmission I will appreciate your help. could you check if it possible to install the cruise control on my car? I can send the VIN number ...
#404 |
Unfortunately no European made Yaris prior to 2012 had cruise control. It was not until the 3rd generation with the 1.33L engine that Toyota added it.
#405 |
I installed CC on my 09 Yaris in the summer of 09 according to CT Scotts instructions. It has worked flawlessly ever since.
I work building electronic devices for space and military applications. I told my supervisor about the CC mod in my Yaris and he looked alarmed. "Paul, I cant BELIEVE you are modifying your brand new car by what some idiot on the internet is telling people to do!"
#406 |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
I also just finished installing the CC mod on my '09 Yaris according to CTScott's instructions 2 days ago. I am still baffled by how easy it was to enable this function.
Before, when I went to a dealership to ask if they could do it, they said they didn't even want to touch it. "If it didn't come with it originally, we can't do anything about it." I would love to go back there now and just laugh at their faces. I'll post some photos once I label all the buttons. Thanks again CTScott! You are trully a Yaris mod master! ![]() ![]()
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
#407 |
Thanks again CTScott! You are trully a Yaris mod master! ![]() ![]() [/quote]CTScott is def the man here. He is "THE DON" or should I say "THE SCOTT" of yarisworld. If he ever traded all three of his Yaris prototypes in for some other car...Yarisworld would not be as good as it is today.. |
#408 |
![]() Drives: 2007 Toyota Yaris 4dr Join Date: Mar 2014
Thanks a million to CTScott for all the help on my 07 Yaris! Cruise control works great!
#409 |
Drives: Yaris Join Date: May 2020
Hi CTScott
I try to instal CC on my yaris 06 , but it did not work !! |
#410 |
![]() Drives: 2007 yaris sedan base Join Date: Apr 2020
I have found several at the local pick your part yards.
#411 |
CT Scott, I will trade stalks for wire harness for cc.
#412 |
![]() Drives: yaris 2018 Join Date: Nov 2020
Has anyone installed CCS on the Toyota Yaris 2018 facelift
#413 |
![]() Drives: yaris 07 hatchi Join Date: Nov 2020
where can i get ecu wire for cruise and wiring harness for clutch switch help
#414 |
where can i get firewall piece i lost it
| Cruise Control Available for 06/07 Yaris | TOYOTaejien | General Yaris / Vitz Discussion | 8 | 08-27-2010 12:58 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
