Old 09-24-2012, 07:56 PM   #1
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
How do you remove the alternator?
I have an 09 sedan. The factory service manual just says to remove the bolts and pull it out. I removed the top 2 bolts and the bottom bolt, but it just pivots. Is there something special you have to do on the 09?
Old 09-24-2012, 08:12 PM   #2
No. It is just a case of it being super tight into that bottom area. You may have to at most pry it out a bit, but typically pivoting it all the way down frees it.
Old 09-24-2012, 09:33 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
and swear a lot
Old 09-24-2012, 09:35 PM   #4
Fidelio
EcoFriendly
Fidelio's Avatar
Drives: 2007 Vitz HB
Careful with the Cam Sensor above the alternator. I damaged mine not knowing it was there using a long screw driver tightening the belt slack. :-(
Fidelio is offline   Reply With Quote
Old 09-24-2012, 09:44 PM   #5
fnkngrv
fnkngrv's Avatar
yyyyeeeeeaaaahhhhhh! One of the guys helping me with my motor swap back in May/June did the same thing whilst getting the alt in the right spot That was an expensive trip.
Old 09-25-2012, 09:28 AM   #6
47_MasoN_47
I ended up having to pull on it while rotating it forward and backward. PITA. CT you weren't kidding about it being tight!
We definitely were referring to the Yaris engine compartment using derogatory language.
DIY : How to remove door panels FEINT DIY / Maintenance / Service 13 11-18-2021 02:16 AM
2003 Yaris High Alternator Voltage drcurzon DIY / Maintenance / Service 3 05-22-2012 04:16 PM
New subcompacts for 2009, 2010 Thirty-Nine Off-topic / Other Cars / Everything else Discussions 24 01-05-2009 01:46 AM
