Drives: 07 hatch 5 door Join Date: Jul 2011
electrical problem 2007 5 door hatchback
My power window fuse or breaker blew (my fault). Is there an electrical manual on line & if not where is the fuse or breaker? The dealer says there is power to the switch but then they want to sell me $1200 electrical box +++, I read somewhere the breaker simply needs resetting. Any info?
There is not a breaker, but rather a fuse. It is located on the face of the under dash fuse panel (which is behind the small storage pocket to the lower left of the steering wheel). It is the 30A fuse, labeled below as "Power". It is not one of the little micro fuses, but rather a larger square style fuse.
![]() Drives: 2007 toyota yaris Join Date: Mar 2013
Is there a main fuse or relay for the fuse panel under the dash? I have my entire fuse panel out of power. except for the panel1 and a/c
I replied in the other thread where you asked as well, but yes the 60A MAIN fusible link on the positive battery terminal.
| electrical problem with car need help badly!! | Adriaan | DIY / Maintenance / Service | 20 | 05-07-2010 12:40 AM |
| Weird door locking problem, electrical? | davembfan | General Yaris / Vitz Discussion | 19 | 09-30-2009 02:50 PM |
| HELP!! HID problem | 07yaris_fe | General Yaris / Vitz Discussion | 2 | 11-20-2006 06:00 AM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 09:12 PM |
| 2007 Registration and Insurance | Vitz-to | General Yaris / Vitz Discussion | 21 | 03-28-2006 09:57 PM |
