Old 11-20-2012, 02:52 PM   #1
Captain Slow
My Face Is Ridiculous
Captain Slow's Avatar
Drives: 2010 Toyota Yaris 3dr LB
Belt noise after MI pulley?
I've got some belt noise after doing the MI pulley. Not squeal, just an audible (windows down sitting in car) sound of the belt spinning around. Is this just a quality of the lighter pulley or should I have my belt checked again? I've never done a lightweight crank pulley before and wanted to make sure this wasn't normal before I started poking around.
Captain Slow is offline   Reply With Quote
Old 11-20-2012, 02:58 PM   #2
I would check your belt tension but it shouldn't make more audible noise.
Old 11-20-2012, 04:16 PM   #3
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
That raises a question... is there any such thing as inaudible noise?
Old 11-20-2012, 04:58 PM   #4
DJYojimbo
Drives: 2012 Grey Toyota Yaris SE
Can u record the video? Maybe Garm can confirm if its normal or not
DJYojimbo is offline   Reply With Quote
Old 11-20-2012, 06:21 PM   #5
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Audible just means that it can be heard by human ears, so yes there are inaudible noises, and dogs can hear sounds we can not.
Old 11-20-2012, 06:31 PM   #6
^ My wife arguing with me, for example.
Old 11-20-2012, 06:44 PM   #7
tooter
play every day
tooter's Avatar
My wife says I have selective hearing.
Old 11-20-2012, 09:07 PM   #8
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
You, too?
Old 11-20-2012, 10:16 PM   #9
Golddeenoh
Golddeenoh's Avatar
apparently i have a some hearing difficult in my right ear, typically that is the side were my wife tends to be when she is asking me something and i get to look over at her while she gives me the stare of death while i have not the slightest clue as to what she said.
Old 11-27-2012, 11:40 AM   #10
Captain Slow
i will record some audio of it later. it's definitely audible though.
Old 11-27-2012, 11:45 AM   #11
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Are there any cracks in the belt? Time to replace?
This thread went from drive belt noise to ignoring complaining women lol
Old 11-27-2012, 12:02 PM   #12
tooter
play every day
tooter's Avatar
My thought is that it could possibly be the anodized surface on which the belt runs which is relatively slippery compared to a raw aluminium surface. If it was me, I'd remove it, mask it off with some tape and beadblast just the belt grooves alone, although lately my solution to everything has been to blast it.
Old 11-27-2012, 12:35 PM   #13
It's all speculation until an actual audio is made available. I don't believe captain is experiencing any noises associated with slippage, as those are very easily identifiable. Also, belt age should not be an issue since the car is only a 2010.
My thoughts, again speculation, is harmonic. The sound resonating from the MI pulley differs from OEM due to its aluminum vs cast construction. He is probably hearing a different 'whirring' sound.
Old 11-28-2012, 11:09 AM   #14
Captain Slow
Yeah, it's not slippage for sure. Just a different (but noticeably louder) sound at idle. I've got a Zoom H2 and will record and post it up later today.
Old 11-28-2012, 07:11 PM   #15
Captain Slow
I've attached the wav file inside of a zip file.
It's just a high-pitched sound as the belt revolves, kinda annoying.
Old 11-28-2012, 10:18 PM   #16
DJYojimbo
Hope Garm can help you with your problem captain! I want to install this pulley too :)
Old 11-28-2012, 10:21 PM   #17
That really sounds like a loose belt to me.
Old 11-28-2012, 10:26 PM   #18
DJYojimbo
How many ft lbs is it supposed to be?
pulling the AC belt pulley on front of compressor yaris9876 DIY / Maintenance / Service 6 07-19-2012 11:12 PM
Squeaky belt after pulley install? Black_griffin6 DIY / Maintenance / Service 12 07-01-2012 11:17 AM
Belt noise? Cutie Pie #2 DIY / Maintenance / Service 20 05-22-2009 02:51 PM
Water pump belt and pulley - replaced at 36,000mi cleong DIY / Maintenance / Service 3 03-06-2009 01:12 AM
Underdrive Pulley Belt ruimond Performance Modifications 11 02-14-2009 10:05 AM
