Old 12-11-2012, 05:54 PM   #1
DJYojimbo
Drives: 2012 Grey Toyota Yaris SE
MI Pulley Black and Red Colors!
These are soooooo tempting to get! Definitely saving up for the black ones! :) Garm you are the man! http://shop.microimageonline.com/MI-...LWCP-Yaris.htm
DJYojimbo is offline   Reply With Quote
Old 12-11-2012, 06:48 PM   #2
bambam28
Drives: Yaris Hatchback 2012 SE
Question...I am planning on buying it...BUTTTT what would be the consequences if it doesnt have the harmonic balancer???
bambam28 is offline   Reply With Quote
Old 12-11-2012, 06:58 PM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Long story short: a harmonic balancer only applies to longer, heavier crankshafts, particularly on inline-6 or V-8's. There is a LOT of discussion on these forums about it, so I'm not going to reproduce all of it here. The bottom line for us is: lots of people have lightweight crank pulleys, nobody has reported any sort of engine failure as a direct result of using one, even under very heavy race conditions.
Old 12-11-2012, 07:10 PM   #4
bambam28
Thank You Crankyoldman...could you try to tell me the power gains is it worth it? I know the acceleration will be better, but since there is less rotational mass it also means there is less inercia...give me your thoughts please :)
Old 12-11-2012, 07:26 PM   #5
CrankyOldMan
I would be willing to bet that it frees up only 3 or 4 HP, but with our little car, it makes a big difference.
Old 12-11-2012, 08:28 PM   #6
DJYojimbo
I heard it helps when going uphill! Since these are already painted? Will they be able to handle salt? I live in chicago. Snow is supposed to come soon I think haha! (No snowstorm yet)
Old 12-11-2012, 11:10 PM   #7
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
It most certainly does! One of the main things I like about mine.
I'd hope so, but I'll find out this winter too. I would think that with the location of the pulley and the way the wheel well lining is that it should remain pretty protected and dry...
Old 12-11-2012, 11:55 PM   #8
DJYojimbo
Jpmck03 thank you sir! I'm hoping to get the MI Pulley mid January or February!
Old 12-12-2012, 08:42 AM   #9
The new pulleys are hard anodized, not painted. The anodizing will help protect against the elements. I don't anticipate any problems with corrosion.
Lightweight rotating elements, like pulleys, flywheels, and wheels/tires, confer more responsiveness and feel than actual measurable horsepower, but it is a noticeable difference.
Old 12-12-2012, 09:53 AM   #10
DJYojimbo
Dang best news ever!
Old 12-12-2012, 12:38 PM   #11
CrankyOldMan
Doh. I oversimplified the result. You're not actually adding horsepower, you're just removing parasitic losses. The net result is that your acceleration curve as a function of time has a steeper slope. I don't think it would show up on a dyno, since that is hp/torque vs RPM, not time.
For racing purposes this means reaching the power band sooner--so your elapsed times will decrease. For daily driving, this means less energy spent spinning up the pulley--decreasing fuel consumption.
I frequently have issues with acceleration wheel spin (outside of ideal road conditions) and my only other engine mod is a drop-in high-flow filter. I can only imagine what a lightweight flywheel and I/H/E would do. Perhaps it would require me to add that magical LSD?
Old 12-15-2012, 12:45 AM   #12
imike929
Drives: '13 Super White SE
how easy of an install is this for say...a beginner? lol
imike929 is offline   Reply With Quote
Old 12-15-2012, 01:32 AM   #13
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I think it would be more like removing inertial force. The motor would work harder to get the heavier stock pully spinning, but the stored inertial energy in the pulley would resist slowing down.
Yes, both the acceleration and deceleration curve would be steeper because of less rotating mass. Essentially a similar effect to a lightweight flywheel.
Old 12-15-2012, 11:47 AM   #14
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
It's not too bad. Jack up the car. Put it on jack stands. Take off the front passenger wheel. Pop off the wheel well panel. Remove the old pulley. Put on the new one. Put everything back together.
There are a few links in my sig on how to install it and a review of the pulley itself.
Old 12-15-2012, 12:01 PM   #15
Hardest part is the one bolt that holds it on. Can be tough to remove (depends on which guy in the Toyota factory put it on there, lol), and should be torqued correctly on install. Make sure you adjust your belt correctly also.
Black Friday Bob_VT Off-topic / Other Cars / Everything else Discussions 70 11-29-2008 07:07 AM
NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) NonStopTuning NonStopTuning 266 09-29-2007 02:51 AM
NEW GROUP BUY: NST Short Shift Kit (NonStopTuning) NonStopTuning NonStopTuning 245 08-28-2007 03:53 PM
FS - Brand New "TRD Styled" Tachometer (Red on Black) Ran Kizama Items for Sale by private party 9 05-09-2007 03:30 PM
