![]() ![]() Drives: 2012 Toyota Yaris Join Date: Sep 2012
What is the largest tire i can fit without rubbing ?
Hi, so our '12 Yaris's OEM tires are 175/65/15 and i would like to increase the clearance during winter and i was wondering what size tire i can fit before i rub on 15' rims .
Thank you, Dan |
If you stay with 175 width you should be able to go with a tire up to 25" in total height (like a 175/75-15). That still only increases your ground clearance by 0.5" and decreases your fender-berg clearance by the same.
Thank you CTScott, so i can safely go with 175/75/15 !...nice
Dan |
![]() Drives: NCP131 Join Date: May 2012
do u think 205/55/16 fit on the 2012 yaris se?
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 10:44 AM |
| Big tire will fit? | Red Horse | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 04-17-2011 06:32 PM |
| I test drove a Yaris, Versa and FIT | CanadaCraig | New YARIS Purchase Forum | 41 | 11-29-2008 10:18 PM |
| Test drove: Yaris sedan 5spd, Fit base auto, Civic LX 2dr 5spd | Bounty Hunter | General Yaris / Vitz Discussion | 7 | 07-11-2007 08:40 AM |
