Old 04-17-2011, 01:15 AM   #1
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
Big tire will fit?
I want to have a tire like 215/70/16 in 16x7 wheel or how big of a tire I can fit on these wheels and I just want to fill the gap from the wheel well,Im also on my stock suspension.
Red Horse is offline   Reply With Quote
Old 04-17-2011, 09:47 AM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
It's tall, but you can fit a 205/55/16 with stock suspension.
Old 04-17-2011, 10:42 AM   #3
rufnnek
rufnnek's Avatar
Drives: oliveMist
with the stock suspension and a 205/55/16 tires doe it look cool? or something?
rufnnek is offline   Reply With Quote
Old 04-17-2011, 03:32 PM   #4
MUSKOKA800
MUSKOKA800's Avatar
I'm thinking they would be way too tall.
Go to Tirerack.com and select any tire in that size then click on SPECS to see its diameter. Our stock diameter is 23.7" Your car will be very sluggish with monster rubber and the tires may contact the inner fenders during compression.
Old 04-17-2011, 05:32 PM   #5
kimona
kimona's Avatar
The Yaris TS, for example, runs 205/45/17's (24.3" diameter) as OEM. Plus, the TS has slightly lower stock suspension than our cars... and there's a fair bit of room left in those wheel wells.
205/55/16's (24.9" diameter) are 2.6% taller than 205/45/17's... which is quite acceptable, particularly considering our cars sit on higher stock suspension than the TS.
In Japan, it's not unusual to see a base model Vitz running 205/50/17's without issues on stock suspension.
However, I believe you may get some minor rubbing on the front fender liners when lock-to-lock.
I remember a few Yarisworld members are running 205/55/16's and 205/50/17's. Perhaps you could do a search and check with them about their experiences with taller tyres.
recurring loss of tire pressure toad Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 12-10-2009 04:54 PM
Test drove Rio5, Fit, and Yaris all today kmf123kmf New YARIS Purchase Forum 16 10-02-2009 07:48 PM
Tire Pressure Max deebrown DIY / Maintenance / Service 82 08-10-2007 09:44 AM
