![]() ![]() ![]() Drives: 2007 black yaris hb Join Date: Feb 2011
dash rattle?
does anybody have an anouying rattle from the top center of the dash... does anybody know what it is and a fix for the problem?
![]() ![]() ![]() Drives: 2017 Yaris L (5sp manual) Join Date: Jun 2012
I've got a rattle from both the left and right sides of the dash. Definitely interested in any ideas. I've tried to identify the source of the sounds, but not having much luck.
OMG! NOT THE 2012 TOOO!!!!!!
I find that the cup holders rattle if they are left open, so closing them when not in use stops the rattle.
A rattle in the center could be from many things including: The cluster screws not being in place, the ducts to the center vents rattling, radio wiring not properly bloused (particularly if an after market one is installed).
They got rid of the awesome dash cup holders for the new gen :( Everything on mine rattles because of the coilovers lol.
ThatYarisGuy
Drives: Toyota Yaris 2012 SE Join Date: Oct 2012
i hear knocking noises on dash area when i steer to the left or right while im driving. idk what it is either
im sorry if im completely out of place here (i drive a 2010 not the fancy dancy 2012) but i fixed most of my dash rattles by putting pressure on it. i stuffed the bottom parts of my A pillars with sponge to compress the dash. worked quite well. i put enough to make it feel solid
Awesome!
Drives: 12 Yaris/07 yaris Join Date: Dec 2010
the top center of my dash used to rattle then just stoped... used to do it when hitting large bumps. mind you i had my 17's on then. and it wasnt bad.
$10.25/hr frying chicken
As soon as it got cold all the rattles came out. Everything rattles in the winter for me
well i was watching a review on youtube and they got the dash rattle after about a week of driving. mine started about a month... when i put pressure on my dash were i think its comming from it stops.... i think theres a wire the just rattles agaist the dash. im kinda affraid to tear apart my dash to find out wut it is.
Makin' it rain
Drives: 2012 Silver Yaris LE Join Date: Dec 2012
![]() Drives: 2013 Yaris SE Join Date: Dec 2012
I think there was a post here on YarisWorld which explained how to remove the "soft touch" material to swap out the audio system. From what I recall, you simply grab the right side of the "soft touch" material and yank it towards yourself to pull it out. That should give you enough space to explore what wires are loose, and where you can add some triple expanding foam from Rona/Home Depot/Lowes.
This may not be the ultimate solution, but the 2012 Yaris could benefit from more sound insulation anyway! |
Awesome!
-30 the suspension freezes and yes, the wonderful creeky rattles.
![]() Drives: Polar White 4 Dr Join Date: Jan 2007
i too have this rattle. it gets worse during cold morning.
I am thinking to put some tape (black electrical) where dash & instrumental cluster meets
2007 Yaris Base Sedan |
at -30*C you need to deal with a frozen clutch too....
![]() ![]() Drives: 2012 Yaris L MT Join Date: May 2012
I have an annoying rattle the came from the right side of the dash. Turns out it was the cover of the USB port making the noise. Still trying to come up with a cure. The cover might be removed with a pair of scissors.
#17 | |
Makin' it rain
To the OP, it took me a few days but I noticed that the metal on the seat belts were bumping on the side pillars of the doors. If you can tuck them into the seam between the seat and frame tight enough that cures some of the more annoying rattles. |
^ The '08 sedan seat belt buckle does same thing . Put some sticky back felt on it . Helps some .
| Make dash less slippery to set coffee cup | alpha1 | General Yaris / Vitz Discussion | 11 | 11-19-2012 10:39 PM |
| Toyota Silver Dash Kit | Meteorite_Marty | Cosmetic Modifications (Exterior/Interior) | 72 | 04-13-2012 01:42 AM |
| 2010 US 5 door stock exhaust, big rattle | 127.0.0.1 | DIY / Maintenance / Service | 3 | 06-20-2010 09:39 AM |
| Dash rattle TSB needed ! | tsportman | DIY / Maintenance / Service | 15 | 07-06-2009 06:20 PM |
| Rattle fixed! | Bretsuaz | DIY / Maintenance / Service | 32 | 03-30-2007 08:39 PM |
