Old 01-23-2013, 11:32 AM   #343
FIREPROOF5
Drives: TOYOTA AXIO FIELDER 07
cant i over ride this and just connect the wires from CC stalk directly to ecm
FIREPROOF5 is offline   Reply With Quote
Old 01-23-2013, 11:34 AM   #344
FIREPROOF5
cant we connect the CC stalk wires (in ur blog) blue and brown directly to ECM after all the clips in between are also doing the same i.e sending electric signals
Old 01-23-2013, 12:29 PM   #345
Since the car is built with a spiral cable that does not have enough wires to support cruise control, it is unlikely that the ECM is programmed for it.
In doing a bit more research on the Axio Fielder, the ones with the same engine as the Yaris (1NZ-FE) do not support cruise control, but the ones with the 2ZR-FE engine do.
Old 01-26-2013, 12:32 PM   #346
adamcorey23
Drives: 2011 Yaris S
I have a 2011 Yaris 5 speed MT, No power , Can i still do the cruise control
adamcorey23 is offline   Reply With Quote
Old 01-26-2013, 04:09 PM   #347
Yes you can. You will just need to do an extra piece (adding the connector D3 pins and running the wire from them to the ECM connector).
Old 06-23-2013, 09:32 PM   #348
exidus
Drives: toyota
Dear Scott,
First of all received your wires 2 weeks ago and as I was out of state was only able to install everything yesterday. My car being a Thailand build Camry 2.0 was quite tight under the dashboard. It works like a charm.I am now happily crusing on my Malaysian highways.
Thanks a million Scott for all the info I needed to make this happen....
exidus is offline   Reply With Quote
Old 07-05-2013, 12:22 PM   #349
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
Guys have a question. And if the connector D3 are already brown and blue wires?
I like very much travel
MickZEL is offline   Reply With Quote
Old 07-08-2013, 08:29 AM   #350
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
Does not work, what to do?
Old 07-13-2013, 06:00 PM   #351
Jadijkstra2000
Drives: Toyota Yaris 2010
Will this be possible on european toyota yaris 2010?
Jadijkstra2000 is offline   Reply With Quote
Old 07-14-2013, 09:10 AM   #352
Jadijkstra2000
Hmmmm got 89661-0dd90... No idea if it supports cc....
Old 07-22-2013, 02:27 PM   #353
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
On European it doesn't work.
Everything works for me. I not correctly tried to include
Old 07-27-2013, 12:04 AM   #354
07liftback
07liftback's Avatar
Drives: 07 Yaris Liftback
Doesn't cruise control usually consume more gas than without it? I would probably start falling asleep if I had it on for too long
07liftback is offline   Reply With Quote
Old 07-30-2013, 01:43 AM   #355
jose3sgte
Drives: Yaris Hatch,Celi 3SGTE,GC8
First of all thank you CT Scott for such helpful guide, I did it to my 06 PR spec Yaris and its been working like a charm for 6 months, I just have a question, Can I use a US S spec cluster (2010) to have the indicators working? I just ordered one from ebay.
jose3sgte is offline   Reply With Quote
Old 07-30-2013, 07:01 AM   #356
Unfortunately the indicator will not work unless you also upgrade the ECM to a 2009 or newer one as well.
I offer an indicator module, which can be used with 06-08 Yaris, which lack the cluster indicator. See my cruise control DIY below for more info on it.
Old 07-30-2013, 08:50 AM   #357
jose3sgte
Is the ecu plug n play? Or I have to look for one in particular? (US or PR spec), Thanks
Old 07-30-2013, 09:02 AM   #358
It is plug and play if it is properly matched. You would need a PR spec one. You would also have to match the car's features - Transmission type, engine immobilizer or not, ABS, Traction control, etc.
Old 08-12-2013, 10:26 PM   #359
Bammer
Drives: Yaris
Clear, concise instructions. Close-up pics. Couldn't have completed the job without this info.
Thank-you.
Bammer is offline   Reply With Quote
Old 08-18-2013, 11:07 AM   #360
YarisBasic
Drives: YRX Black 4 doors seden
is anyone know, will the Rostra cc kit work on Australia model (2007) manual sedan,
Thank
Lewis
YarisBasic is offline   Reply With Quote
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
