Old 01-23-2013, 11:56 AM   #73
VitzHead
Drives: 2009 Vitz 1.5 RS
CRAZY .... LOL
VitzHead is offline   Reply With Quote
Old 01-24-2013, 02:29 PM   #74
Pro-Street
Pro-Street's Avatar
Drives: Yaris 1.8 supercharged
Nice Car Bro
Pro-Street is offline   Reply With Quote
Old 01-29-2013, 09:08 PM   #75
DINOeggxo
DINOeggxo's Avatar
Drives: white yaris hatchback.
I still have the pictures of her car on my phone for wallpapers lol. i wish I could afford to bag the new yar, guess I'll just stay static and dare to go as low someday :p
<3 i will have more good pictures this year i have a few photoshoots lined up. very legit. :)
Originally Posted by titoo20 View Post
what a great yaris! +1 respect
love it so much!!!
ee! thanks. <3
Originally Posted by UberSilver View Post
Just by looking at your rig, I can tell I'd like you! You've Got Character!
thanks<3
Originally Posted by VitzHead View Post
CRAZY .... LOL
very crazy. indeed.
Originally Posted by Pro-Street View Post
Nice Car Bro
thanks
-though no problems during the winter with the air set up really wish it would snow again for a fun winter shoot.
DINOeggxo is offline   Reply With Quote
Old 01-29-2013, 09:46 PM   #76
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Wee nee sum updates.
Old 01-29-2013, 10:30 PM   #77
vten
Next update would be together with me , right Dino ?:P
Old 02-01-2013, 05:47 PM   #78
DINOeggxo
DINOeggxo's Avatar
YEPPPPPP
Old 02-02-2013, 08:20 AM   #79
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
in for updates.
Is the air stored in the tank in liquid form or gas form? Do you have anything installed to help regulate/monitor temps within the system?
Who are you getting covered by?
Old 02-02-2013, 12:21 PM   #80
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Air is gas as in oxygen. It's like adding air into your tires, except the air stored in a tank. There usually is a monitoring system with either analog gauges or digital gauges. It will tell you how much air (in psi) is in the tank and how much air is in each bag. No temperature gauge needed.
In for updates as well. Need more pics!
Old 02-02-2013, 01:03 PM   #81
1.5
Form>Function
1.5's Avatar
Typically when tanking a gas (ie: O2), the gas is compressed into a liquid form. This allows larger amounts of the molecule to be stored as the density of the molecule is increased thus freeing up space. I was just wondering if that is how these systmes operate. THat most likely would make it easier for the O2 to freeze.
What happens if the monitoring system reads the temp too cold or hot? Is there a failsafe that closes the lines or anything?
Old 02-02-2013, 03:52 PM   #82
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
The air compressed in the tank is less than 200psi. It doesn't turn into liquid oxygen. Converting gaseous oxygen to liquid form would require several processes which would included cooling the gaseous oxygen at some -300 degrees. There may be a little heat generated in the tank from compression but not to a level that would be considered dangerous at all. It also doesn't freeze at all. Sometimes you might have to release some air from the tank into the atmosphere because the air in the tank can have moisture. When you do that, the air (and unwanted moisture, usually water) that exits will be a little cold. But it's not "freezing" like you would imagine.
The air suspension setup is basically like pumping your tires at the gas station. At the station, there is a tank, a compressor, a pressure regulator and hose with a valve. When you pump air into your tires it comes from the tank. When the tank runs low, a compressor kicks in and refills the tank. A pressure regulator sets the psi and tells the compressor to stop when air is filled to that psi level.
Now imagine you had that exact same setup except that it's all in your car. And instead of pumping your tires, you're pumping air into the airbags of your suspension. That's basically it. You could actually pump your tires from the tank if you attach a long enough hose to reach your tires.
There really isn't a "failsafe" but it usually fails if not installed properly. Common problems would be improper connections which causes air to leak or the rubber on the bags have rotted or cracked. Air suspension has actually been around for a long time (see huge semi-trucks that haul huge loads cross-country). It's just on a smaller scale now and available to the public. So problems mostly occur from not installing it properly. Otherwise they should last the life of your car ownership.
Hurry up DINOeggxo. Need updates NOW!
Old 02-02-2013, 08:31 PM   #83
DINOeggxo
DINOeggxo's Avatar
i don't air out as much. my tank will drain it self over night due to temp change. i did not put anti freeze in my tanks. i know a lot of vw people do this. the shop that installed my air told me not to as he never needed it. i will air out when it hits 25 degrees F and up but nothing below. i never had an issue with anything freezing. which is good :) i don't have anything else installed for the winter to help with the air set up its the same as it was in the summer. somehow i think it works better in the winter.... lol
Old 02-02-2013, 08:41 PM   #84
DINOeggxo
DINOeggxo's Avatar
we have so much snow now, as it fell during the night. If its not -287382 degrees out winter shoot will happen.
Old 02-02-2013, 10:08 PM   #85
1.5
Form>Function
1.5's Avatar
And if the air is pure O2 has a freezing point of like -390F and its condensation point is like almost -200f so I guess you wouldn't have to worry about that lol
Old 02-02-2013, 10:21 PM   #86
DINOeggxo
DINOeggxo's Avatar
lol
Old 02-03-2013, 07:35 PM   #87
DINOeggxo
DINOeggxo's Avatar
teaser shoot 3 locations with my cute little eggy<3
Old 02-03-2013, 07:39 PM   #88
1.5
Form>Function
1.5's Avatar
Ooooooo
Old 02-04-2013, 12:29 PM   #89
DINOeggxo
DINOeggxo's Avatar
http://www.flickr.com/photos/makswel...n/photostream/
First picture from the shoot <3
Old 02-04-2013, 12:33 PM   #90
vten
Hot hot hot !!!
Mini Cooper Wheels on my Yaris Bmcguigan1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 04-01-2012 02:04 PM
