Old 08-05-2011, 03:53 PM   #1
Bmcguigan1
Bmcguigan1's Avatar
Drives: 2009 Toyota Yaris 5dr hb
Mini Cooper Wheels on my Yaris
Sorry for any repeated threads but I am new to upgrading wheels and wondering if these will fit....
Inside of rim says 7JX17EH2
HERE IS A PHOTO....Can anyone confirm these fit the Yaris?
Help is greatly appreciated!
I have found another yaris with a mini oem wheel but it wasnt this exact design
Bmcguigan1 is offline   Reply With Quote
Old 08-05-2011, 04:42 PM   #2
Cosworth
Drives: S sedan
I have a set of 15" mini wheels and they work great! (Thanks, CTScott!)
You will need a hubcentric adaptors and correct lug nuts to make it fit correctly (and safely).
To really tell you if it will fit correctly, you need to find the offset info for the wheel. It usually says ETxx or +48 .
Cosworth is offline   Reply With Quote
Old 08-05-2011, 04:43 PM   #3
Bmcguigan1
Bmcguigan1's Avatar
I found the ofset to be ET48....
Old 08-05-2011, 05:20 PM   #4
Bmcguigan1
Bmcguigan1's Avatar
The bolt pattern is 4x100mm.
The centerbore is 56.1mm...ET48? Found these specs on a MINI Forum for these wheels
Old 08-05-2011, 06:09 PM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
With correct lug nuts, they will fit just fine.
Old 08-06-2011, 08:24 AM   #6
Cosworth
Drives: S sedan
with that offset, you'll be just fine. Make sure to get correct lug nuts. I can take pics of my lugs if you need a reference.
Old 08-16-2011, 10:00 PM   #7
SoILoveMyYaris
SoILoveMyYaris's Avatar
Drives: 2010 Red Yaris
Hi, which are the correct lugs that I need to use? Also I was wondering whats the size of the hubcentric adaptor that I would need to use. Thanks!
SoILoveMyYaris is offline   Reply With Quote
Old 08-16-2011, 11:46 PM   #8
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
see this thread that CTScott provided - reference for those who plan to install Mini Cooper rims on their Yaris.
This was the link from JEGS that he provided about the lug nuts (lugcentric type)
lugcentric nuts and adapters (courtesy CTScott)
Old 09-03-2011, 09:45 AM   #9
JTDBT903
JTDBT903's Avatar
Drives: '08 SEDAN 5 SPD.
Why not get this set of 20, with locking nuts and valve stems! JEGS
Cheaper too!
JTDBT903 is offline   Reply With Quote
Old 04-01-2012, 02:04 PM   #10
"G"
Drives: 2007 Yaris Hatch
I would not use those chinese lug nuts on my car. Buy these >> http://www.otisincla.com/category/ot...x_19.off_road/
"G" is offline   Reply With Quote
mini cooper rims, wheels
Mini cooper wheels?! T Pexx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 04-05-2012 08:55 PM
