Old 02-12-2013, 11:48 PM   #1081
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I get more tire noise than anything else, and think it's a combination of hollow spoked alloy rims and inherently noisier tires (Bridgestone Potenzas). Still I don't have any real complaints because the exhaust makes such beautiful music.
Also got a pleasant suprize... my first registration renewal. It was only $187... and this is for a one year old car. My 17 year old pickup truck is $93.
Old 02-13-2013, 07:32 AM   #1082
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
^ They did a whole bunch of things to reduce cabin noise -- intake system, exhaust system, firewall materials, etc.
My 01 Echo was considerably quieter on the intake side.
Old 02-13-2013, 11:00 AM   #1083
tooter
play every day
tooter's Avatar
Mine's a little less quiet...
Old 02-13-2013, 11:16 AM   #1084
^ Tooter, a great project for tire/road noise is to treat your wheel wells with undercoating. Herculiner is a great product for this (but there are also spraycan products readily available) and you'll get a noticeable result.
Old 02-20-2013, 06:35 AM   #1085
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
On a mildly related note, I've just picked up a Blitz S/C, and I'm already thinking of how I can make it work on a 2ZR-FE swap. The first (and craziest) idea was to have a new manifold section cast from aluminum to mate with the wider bore pitch. Expensive, crazy, probably won't end well. The second thought was (drumroll please) to get an adapter made to mate a 1NZ manifold to a 2ZR head. And then it hit me: someone already did! Of course this assumes that the bolt patterns and bore pitch are identical between the two different 1.8L engines, but I'd say there's a pretty good chance of it being the same.
Old 02-20-2013, 09:09 AM   #1086
Captain Slow
My Face Is Ridiculous
Captain Slow's Avatar
Drives: 2010 Toyota Yaris 3dr LB
^ beat me to the Blitz :(
haha
Good luck with it and hope to see some pics/vids once it's installed.
Captain Slow is offline   Reply With Quote
Old 02-20-2013, 12:08 PM   #1087
tooter
play every day
tooter's Avatar
You're living up to the name Captain Slow.
Old 02-20-2013, 02:02 PM   #1088
Captain Slow
I was only second :D
Old 03-02-2013, 10:05 PM   #1089
tooter
play every day
tooter's Avatar
I ran out of tooter adaptors (and manifolds) and ordered a couple more. This offered the opportunity to slightly tweak the design to remove the 2mm step around the top perimeter so that I don't need to round it off with a Dremel any more...
Old 03-03-2013, 07:43 AM   #1090
CrankyOldMan
Conical taper, eh? I'm planning on going to visit my S/C this afternoon so I can take some pics and rubbings. I figured the best way to get scale representation of the surfaces is to do the old graphite-on-paper transfer trick and then add measurements by hand.
Old 03-03-2013, 09:18 AM   #1091
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
according to one of the Yaris manuals that screen is for noise reduction. anybody running without it???
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 03-03-2013, 12:36 PM   #1092
tooter
play every day
tooter's Avatar
Not yet...
You know, I thought about that metal lattice and was searching online to see if anyone else had any negative effects from removal. All I could find was problems with a screen on older cars, but that was in front of the MAF sensor. Removing it messed with the idle and A/F ratio for some vehicles. I can't see how removing it would cause any problems, although I thought it might make for smoother less turbulent airflow across the backside of the butterfly when it's less than fully open. The air flow over the tipped in end of the butterfly is smoother because it's slanted in the right direction whereas the backside tips upward into the airflow.
I just played it safe and used standard readily available off the shelf stock Toyota O ring gaskets on both ends. The metal lattice can simply be snipped out if desired.
Old 03-03-2013, 12:41 PM   #1093
tooter
play every day
tooter's Avatar
Yes, the machined taper is so slight and even you can't see it...
...and naturally everything gets bead blasted.
Old 03-04-2013, 07:14 PM   #1094
tooter
play every day
tooter's Avatar
Oh, oh... looks like tooter has gone off on another adventure...
This one was totally nasty. It took a whole can of engine degreaser just to get it looking like this. I hate working with dirty parts, so at least I can handle the manifold without getting black hands.
...and this one is pure R & D (Research and Development). I haven't yet decided exactly how to go about this because it's something totally outside the box. So I'll let you guys know when my idea actually takes shape.
Old 03-04-2013, 07:27 PM   #1095
CrankyOldMan
MUAHAHAHAHAHAHAHA!
Old 03-04-2013, 09:39 PM   #1096
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Awesome! Can't wait 2 see what you come up with..
JustDidIt is offline   Reply With Quote
Old 03-05-2013, 11:57 AM   #1097
tooter
play every day
tooter's Avatar
It's gonna be a real doozy...
I'm sourcing the raw materials.
Old 03-07-2013, 11:26 AM   #1098
malibuguy
Obsessed with 1.5L
i like your thinking
-96 Tercel 4dr
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
