![]() Drives: 2007 toyota yaris Join Date: Mar 2013
Fuse panel
I have a 2007 Yaris and the entire fuse panel under the dash is out except for the (2) 7.5 fuses which i think is the ignition and not sure of the other. Does anyone know if there is a main fuse or relay that controls the entire panel under the dash?
Yes - The 60A MAIN fusible link on the positive terminal of the battery feeds the majority of that fuse box. It is built into the black plastic chunk that sits under the red cover.
That is it. where can I get one now is the problem lol. Thanks for your help.
That is pretty much a dealer or mail order part only, that whole plastic block has to be replaced.
is there any way i can make my own fusible link like that out of parts from autozone?
You basically need to bridge the popped fuse with the guts of an equally rated fuse. You would have to trim back the existing one a bit and then solder the new one to the two ends of the old one.
| 30A Power Fuse Instrument Panel Location? | Kioshi | DIY / Maintenance / Service | 16 | 03-31-2013 06:53 PM |
| DIY rear Interior panel removal 09 3dr LB | bkndacn | Cosmetic Modifications (Exterior/Interior) | 10 | 03-11-2013 01:05 AM |
| Instrument Panel Fuse box location?: Yaris T3 Spirit | tony005 | DIY / Maintenance / Service | 3 | 06-22-2012 10:10 AM |
| where is the friggin fuse panel? | darkMINI | DIY / Maintenance / Service | 4 | 08-11-2010 03:24 AM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
